Suction mounts on a canopy
Old April 11th 07, 10:40 AM posted to rec.aviation.soaring
db
Default Suction mounts on a canopy
Is there any trick how to prevent suction mount with a relative heavy gps
device on it (G96) to fall off the canopy every half an hour or so?!
The canopy is new, surface is perfectly clean, almost flat (blanik's canopy
starboard side), tried two diferent suction mounts, one with light PDA
device mounted but the result is the same - it is always falling off the
canopy!
Old April 11th 07, 11:32 AM posted to rec.aviation.soaring
Mal[_3_]
A small amount of spit for a seal and do it while the air is at low pressure
eg while as high up as possible.
Old April 11th 07, 12:36 PM posted to rec.aviation.soaring
Clint
I was using very effective suckers with a locking action - until the
dangers of cracking canopies was pointed out.
Clinton
LAK 12
Old April 11th 07, 02:30 PM posted to rec.aviation.soaring
Paul Remde
Hi Clinton,
Good point! I sell a suction cup from RAM called a RAP-224-1 that pulls a
hard vacuum when you rotate the locking ring. I don't recommend it for use
on glider canopies because it pulls the canopy out of shape - which could
cause crazing or other damage in the long run. I would never use one on a
glider canopy, but it works well on glass windows in cars.
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"Clint" wrote in message
Clinton
LAK 12
Old April 12th 07, 08:22 AM posted to rec.aviation.soaring
db
pressure eg while as high up as possible.
Well, seems this works fine, I have just tried this technique on a 3.5 hours
flight up to 7000 feet.
Suction mount fell off after 30 minutes of flight (after being attached on
the ground), but it didn't fell off after being attached on 7000 feet!
I'll try water instead of spit next time.
Old April 11th 07, 02:26 PM posted to rec.aviation.soaring
Paul Remde
Hi,
Have you tried the RAM-B-224 suction cup mounts that I sell? They work
great for me and I've sold hundreds of them to glider pilots around the
world. If you clean the canopy and wet the suction cup it should never fall
off. I use mine to hold an iPAQ hx4700 with large battery and CF GPS with
no problems. It has withstood the 4Gs of a loop and the bumps of a landing
on a grass runway in a Ventus with no shock absorber and the tire pumped up
to a high pressure - very bumpy.
It should hold your large Garmin fine as well.
If you have tried that suction cup without success then you may have
received a defective one that could be replaced free of charge.
You can see details he
http://www.cumulus-soaring.com/ram.htm
Good Soaring,
Paul Remde
"db" wrote in message
canopy starboard side), tried two diferent suction mounts, one with light
PDA device mounted but the result is the same - it is always falling off
the canopy!
Old April 11th 07, 06:28 PM posted to rec.aviation.soaring
flying_monkey
On Apr 11, 9:26 am, "Paul Remde" wrote:
Hi,
You can see details hehttp://www.cumulus-soaring.com/ram.htm
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.http://www.cumulus-soaring.com
the canopy!
Just to reinforce what Paul says, I bought that suction cup mount from
him. It holds my Axim just fine. It never comes off. I hate to say
this, but I usually lick around the edge, then stick it on. But I
have to remember to clean the inside of the canopy _really_ well, or
my partner gives me such a ration of s**t that I can hardly stand it.
"There's no reason to ever touch the canopy." Well, sometimes, ya
gotta.
In my truck, I use the same Axim for navigation, and there I have a
smaller suction cup with a toggle lever on it that holds for weeks at
a time, but eventually falls off. Paul's suction cup is much better.
Ed
Ed
Old April 11th 07, 11:11 PM posted to rec.aviation.soaring
Andreas Alin
Well, not if you fly ASW 15. I have to touch it after each landing... no
way to get out without touching. ;(
Andreas
Old April 12th 07, 12:10 AM posted to rec.aviation.soaring
Bernie[_2_]
Has anyone ever seen a canopy cracked by a 'lever-action' suction
device? You've got me worried now ..........
Old April 12th 07, 02:06 AM posted to rec.aviation.soaring
I read somewhere that water will work better than spit, and my own
experience reinforces this. I can't explain why, but try water
instead of spit. Fred
Lycoming O-360 oil suction screen torque [email protected] Owning 8 August 19th 06 07:52 PM
PDA suction mount? Bernie Baer Soaring 7 August 17th 06 02:21 AM
G-force vs. Ram GPS suction mount [email protected] Piloting 9 October 20th 05 10:51 PM
Suction mounts for Garmin 296 Ekim Piloting 5 June 25th 05 10:55 AM
Effect of suction on DG Jay Honeck Owning 6 March 3rd 04 01:12 PM
