WAS: Laminating an Aileron Spar NOW: how much wood should I leave at narrowist point?
Old April 12th 07, 01:41 AM posted to rec.aviation.homebuilt
Michael Horowitz
Default WAS: Laminating an Aileron Spar NOW: how much wood should I leave at narrowist point?
Although I only have to add 1/4" to the edge of my spar to allow me to
cut a bevel, if I use that minimum, when I cut the bevel, I will leave
only the thinist piece of wood covering the joint. That strikes me as
not good, so I'm thinking after the bevel I need a substantial
thickness at the narrowist part.
Anyone have a feeling for how much wood should be left after the bevel
is cut? 1/8"? - Mike
Old April 12th 07, 02:03 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Default Laminating an Aileron Spar NOW: how much wood should I leave at narrowist point?
Don't worry about how thin the piece is. The glue is stronger than the
wood, remember?
Pay attention to the run of the grain. You do not want any grain rising
quickly to the surface, especially on a thin piece.
What I would definitely NOT do, is cut the spar thinner, just so you can
have a thicker edge on your added bevel piece. Keep all of that spar
strength that there is, in one piece. You may need it someday. g
Laminating an aileron spar Michael Horowitz Home Built 12 March 28th 07 05:23 AM
How do you leave this airport IMC? Journeyman Instrument Flight Rules 45 June 1st 05 01:18 PM
DId Greybeard really leave [email protected] Soaring 4 March 12th 05 07:03 PM
Before I leave Rah wingsnaprop Home Built 14 December 21st 04 01:15 AM
Last two C-141s leave McGuire AFB Otis Willie Military Aviation 0 September 18th 04 12:34 AM
