Pegasus Rudder Cables?
Old June 23rd 07, 02:20 AM posted to rec.aviation.soaring
Bill[_9_]
Default Pegasus Rudder Cables?
Does anybody know the diameter of the Pegasus rudder cables? Will
eighth-inch work?
Bill
Old June 24th 07, 02:24 PM posted to rec.aviation.soaring
JJ Sinclair
eighth-inch work?
Bill
Yes
JJ
Old June 24th 07, 06:27 PM posted to rec.aviation.soaring
El Alumbrado
"JJ Sinclair" wrote in message
ps.com...
eighth-inch work?
Yes
Thanks much.
Posted via NewsDemon.com - Premium Uncensored Newsgroup Service
-------http://www.NewsDemon.com------
Unlimited Access, Anonymous Accounts, Uncensored Broadband Access
Old June 24th 07, 10:26 PM posted to rec.aviation.soaring
CindyASK
Hmmm.
Yes, I know the cable size?
Or, yes, one eighth inch will work?
It made me wonder why the removed/removing/extant cable size hadn't
been measured.
But sometimes I have a way too logical moment to really be blonde.
By the way JJ, congrats on racing that US design to a high placing
finish.
Best to all,
Cindy B
On Jun 24, 10:27 am, "El Alumbrado"
Yes
Thanks much.
Old June 25th 07, 12:44 AM posted to rec.aviation.soaring
El Alumbrado
"CindyASK" wrote in message
Hmmm.
been measured.
It's not you being blonde, it's me not telling the whole story. The airplane
and I were not co-located, making measuring problematical. I was guessing
1/8th inch 7x19, but wanted to order some cable ASAP, so I thought I'd ask
my friends and neighbors for confirmation.
Hope you don't mind.
Bill
Old June 25th 07, 01:43 PM posted to rec.aviation.soaring
JJ Sinclair
finish.
Best to all,
Cindy B
Thanks Cindy,
It was a good race with good tasking, like Bishop-Basalt and Mammouth-
Mina, even called Independance with a circle one day. On the last day
it was blowing like stink, 30 knots at 10K. The bat-wing just couldn't
penetrate as fast as the heavy Ventus-2 CM, so my speed wasn't enough
to hold on to first place. Got me fored up and I'm still hoping to get
into Parowan, may even try to make it down to Hobbs.
Best regards,
JJ
Old June 25th 07, 09:01 PM posted to rec.aviation.soaring
Doug
Just be aware that the "new" rudder pedals for the AD have a plastic sleeve
that is slightly smaller in diameter than the old one, so the cable may not
slide through it easily when adjusting the pedals, and may pull the sleeve
out of the "S" tubing.
Gotta love these rudder AD's.
Doug
ps.com...
eighth-inch work?
Bill
Yes
JJ
Old June 26th 07, 02:13 AM posted to rec.aviation.soaring
El Alumbrado
"Doug" wrote in message
sleeve that is slightly smaller in diameter than the old one, so the cable
may not slide through it easily when adjusting the pedals, and may pull
the sleeve out of the "S" tubing.
Thanks for the tip. I've got to believe it's safer to leave the existing
bits in place than go monkeying about installing new pedals and cables. How
hard do you have to stomp on the pedals to crack them, anyway? I suspect I
could beat the old pedals with a hammer for a few hours with no ill effect.
El Alumbrado
Tempus Fugit, Memento Mori
Old June 26th 07, 02:51 AM posted to rec.aviation.soaring
JJ Sinclair
I suspect I
In an accident, like a high speed ground-loop, the pilot may end up
more or less standing on the rudder pedals. I have seen cracked rudder
pedals where there was no damage to the nose of the
glider.......................I suspect this was the issue that lead to
this AD.
JJ
Old June 27th 07, 08:02 PM posted to rec.aviation.soaring
Doug
In our case, there was a small crack starting on one of the rudder pedals at
the weld. The area actually looked slightly compressed as though it had been
squeezed in a vise. Still, it would have taken a mighty heavy foot to
actually break it. I suspect a vertical nose down landing, ouch, would have
accomplished that. I wish we could have just welded on a reinforcing plate,
like they did on the new pedals, to solve the problem because the new pedals
are narrower and much more uncomfortable to use.
Doug
I suspect I
effect.
this AD.
JJ
New PDA data cables for EW microRecorder Paul Remde Soaring 0 January 4th 07 08:31 PM
FS: Piper Booster cables Ottprivatesale Owning 0 July 11th 06 04:36 AM
unsticking cables dlevy Owning 12 January 8th 06 09:39 AM
MiG-29 cables alcatraz Military Aviation 0 March 1st 04 10:01 PM
Control cables for gliders mike maskell Soaring 10 January 1st 04 05:08 AM
