halon- full inhalation
Old July 7th 07, 04:24 AM posted to rec.aviation.homebuilt
angie1971
Default halon- full inhalation
Hi there.
Seems to be alot of discussion on the halon dry chem, used in fire
extinguishers.
My unfortunate luck would put me in fornt of an emergency self pull trigger.
It actually is used in the engine compartment where if you have a fire break
out, it is able to self extinguish the area without the human pulling out the
pin. Usu. takes a high temp to do this though.
Back to my bad luck story. I was building luxury, or not, big boats, in
Roseburg, Oregon. Soecifically...Bayliner Marine, of Brunswick, COrp.
LOLOLOL!! I was within no more than 1.5-2" away form the damn thing and
IT WENT OFF!! Yep right into the mouth of mine. Nicely done! Oh this may
have been about 5 yrs ago, but YES still having alot of bronchial porblems
that are too gross to explain. I screamed when it blew, and tried like heck
to cover my mouth and eyes, was wearing a solid silver ring that completely
disappeared like into thin air form the extreme freeeze it put out. I
suffered a major coughing attack and was rushed to Mercy Med Emerg, whrere of
course, just like Bayliner, had no idea about an MSDS sheet or who/what halon
even was!! That's seriously retarded! I cannot figure out later why I got a
write-up when I was no where near the damn thing with another body part,
other than my mouth, and it wasn't like I was sucking on the trigger, or even
would consider doing this retarded act to sponge off the ill-skilled workers
comp insurance!!
Even though this was an accident I am still left without any type of
compensation. I am not a gold digger but dang! I read several different
entries here of the halon comments and stories. They sure did help ease some
of my hysteria for the moment. I know it just sits in the black bottom of
whatever it got into, but think about your lung capacity for a moment. OK
then, what is the trade off where it is sitting... how much of my lungs
really have their true function if they are simply buried in an unknown amout
of halon??
Follow me??
I am certainly concerned for my longevity (life).
ANY SERIOUS HELPFUL HINTS OR TIPS?? I AM KINDA POOP OUT OF LUCK IN EVERY
SINGLE SITE I HAVE POSTED MY QUESTION.
I GRACIOUSLY APPRECIATE EVERY BIT OF HELP I CAN MUSTER, BECAUSE EVERYWHERE
I'VE TURNED HAS LEFT ME WITHOUT A DROP OF INFO, NOT TO MENTION THE WILD GOOSE
CHASE THEY SENT ME ON...
VERY ANXIOUS,
ANGIE BENEDICT
THANKS AGAIN!
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...built/200707/1
Old July 7th 07, 04:53 AM posted to rec.aviation.homebuilt
Scott[_1_]
Maybe this will help...
http://erd.dli.mt.gov/safetyhealth/brochures/halon.pdf
Scott
angie1971 wrote:
Hi there.
extinguishers.
comp insurance!!
of halon??
Follow me??
VERY ANXIOUS,
ANGIE BENEDICT
THANKS AGAIN!
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Old July 7th 07, 01:00 PM posted to rec.aviation.homebuilt
Ron Natalie
Actually, absent any actual fire and as long as you don't get so
confined with the flood of Halon that you can't believe, the stuff
is pretty inert. It does like any expanding liquid get very cold.
There are some obnoxious products (HBr, HCl) liberated when the
stuff is interacting with fire, but those are in fairly small
quantities.
Most of my info on Halon comes from a couple of NFPA booklets
on the subject I got back when I was working with the stuff in
the computer industry.
Old July 7th 07, 02:42 PM posted to rec.aviation.homebuilt
Peter Dohm
m...
quantities.
That is the same info as I had from the few halon extinguishers to which I
have had access when I worked on electronic equipment, and also when
recently studying for a refrigerant license. There are actually a number of
halons; so that specific information, such as an MSDS, might require a
little information from the label on the extinguisher. With that as a
starting point, the rest is only a Google (or Yahoo) search away.
Peter
Old July 8th 07, 01:39 PM posted to rec.aviation.homebuilt
Ron Natalie
The two fire fighting ones in user are 1309 and 1211. You
small hand extinguisher probably is 1211.
Old July 9th 07, 07:26 PM posted to rec.aviation.homebuilt
wright1902glider
Did you have any injuries from the freezing gas? I once made the
mistake of touching the side of a propane tank that was cryogenically
cold. It was an ordinary barbeque cylinder, but I was burning the gas
off at a very high rate through the 'ole Cajun Crawfish Cooker. Well,
before you could say doubble-dog dare, my right hand froze to the side
of the tank. The result: 2nd degree "burns", abscence of fingerprints
for 4 months (scars are smooth), and lingering nerve damage. Some days
it pays to be left-handed.
Harry
Old July 13th 07, 10:26 PM posted to rec.aviation.homebuilt
angie1971 via AviationKB.com
YES! I suffer now from serious lung phlem,choking me out sometimes. I
appologize for the lack of urgency on my part of not replying to you more
quickly.I still am not sure about the long term effects of my inhalation, but
I will say this, I sure never suffered from what I have to deal with now!
Bayliner Marine here in Roseburg, Oregon is where I was working when this
happened, and they aren't and still haven't, helped me out AT ALL with any of
this. No info or med or anything! I have a huge amount of links though, that
you might find usefull, as did I. That's how I ended here with all you very
helpful and real people.
In fact if you do want them leet me know and I will email them to you. But
they are all on HALON. Thank You, by he way for your contacting me on this.
I still don't really know alot about HALON gas. I still can't get any info
from the sites that handle this kind of stuff. Really. They don't even know
about it some of the times I contact them. Funny HuH? Well I will check my
email more often and try to get back to you more quickly. Thanks so much for
your question. Did you suffer any long term effects from the propane?
Normally the two are never combined, as far as I've learned, but the HALON is
in it's own class of gases I guess.
Oh yeah, by the way, propane is very apt to do that, what it did to you.
Very common, heard of a guy that lost his entire hand due to a release of
propane from filling a tank. Scary.
talk later. Angie B.
Harry
Old July 13th 07, 10:28 PM posted to rec.aviation.homebuilt
YES I believe that is the same as I experienced. I am trying to find my
notes on it. Ihave about a hundred or so of them. hahaha. but really.
Message posted via http://www.aviationkb.com
Old July 13th 07, 11:34 PM posted to rec.aviation.homebuilt
Yes I understand that from all of the info I've read that are a few different
numbers that exist for HALON. I believe 1211 is the right one.
What exaclty did you get out of your prior stuff from what you typed here?
Is there anything that you reaad that describes what it does if you inhale it
directly? I have found nothing in all the sites I've gone to that has
anything on my deal...I only found the same for being confined and the
experiments on men and some raats and dogs. nothing I mean nothing on my
same deal. I have alot of sites that were given to me from a guy in the EPA.
He had never even heard of HALON. Go figure. Thanks for getting back to me. I
wish I knew what the effects of it were, because I think I suffer from it. I
would like to know if I had a chance to bring it to the work comp jerks in my
area.
Thaks again for the reply, I appreciate!! Talk later, Angie B.
[quoted text clipped - 7 lines]
Peter
Old July 13th 07, 11:44 PM posted to rec.aviation.homebuilt
Mark Hickey
I'm thinking that the problem very likely isn't that the gas your
lungs were abused with, but the sheer pressure and maybe temperature
of it. I used to scuba dive, and we were drilled relentlessly on
proper technique to come to the surface. Since there's a one
atmosphere change in pressure every 33 feet or so, it's really quite
easy to rupture tissue in your lungs ascending without exhaling. My
SCUBA instructor claimed that you can injure / kill yourself in
relatively shallow water (like a swimming pool) if you take a really
deep breath and surface quickly.
From the description of the incident, it's hard to imagine you didn't
end up with some pretty serious pressurization in your lungs, and if
so, that would have to have ruptured some of the air sacs and other
various bits. You wouldn't have the typical nitrogen narcosis
associated with a diving incident since the there isn't any nitrogen
in a halon bottle (an assumption, however).
You might look up a doctor who's been schooled in treating divers and
see if there's anything they can add.
Mark "lobster hunter" Hickey
Q. Canadian Homebuilt: Fire Extinguishers - Halon RV9 Home Built 31 July 22nd 05 05:08 AM
Radio protocol regarding full stops on full stop only nights Ben Hallert Piloting 33 February 9th 05 07:52 PM
Halon Fire Extinguisher? O. Sami Saydjari Owning 14 May 4th 04 10:27 PM
FA: halon fire ext system for homebuilts N329DF Home Built 0 August 16th 03 03:12 PM
FA: AIRCRAFT/RACE CAR HALON FIRE EXT SYSTEM N329DF Aviation Marketplace 0 August 16th 03 03:11 PM
