Avionic weather-stripping seal needed...
Old July 22nd 07, 06:43 PM posted to rec.aviation.soaring
Default Avionic weather-stripping seal needed...
Has anyone replaced weather-stripping seals on Avionic trailer? I got
a quote of $350 for the seal. That sounds a lot for 50 feet of rubber.
Does anyone have a resonable source for weather-stripping seals?
Old July 22nd 07, 07:35 PM posted to rec.aviation.soaring
Frank Whiteley
www.mcmaster.com has a selection, search seals, rubber seals, weather
stripping and see if you can match something up
Frank Whiteley
Old July 23rd 07, 04:30 PM posted to rec.aviation.soaring
Tim Mara
the weather strip used on most trailers including cobra and komet is the
same material used to seal coffins!
tim
Old July 23rd 07, 04:46 PM posted to rec.aviation.soaring
tim
Does anyone have a resonable source for weather-stripping seals?- Hide quoted text -
- Show quoted text -
Sounds like a dead of winter project.
flyer
Avionic trailer wheel needed qflyer1 Soaring 6 December 7th 06 03:30 PM
LS3 flaperon gap seal template needed Birdbones Soaring 2 May 14th 05 12:46 AM
Avionic Install/Replacement Certification David Salvagnini Owning 3 April 4th 05 06:41 AM
Avionic question for Mr. Jim Weir Henning DE Home Built 4 September 19th 04 09:07 AM
Avionic trouble Henning DE Home Built 1 September 10th 04 10:23 PM
