Instrument Accuracy
Old August 17th 07, 04:07 PM posted to rec.aviation.soaring
RN
Default Instrument Accuracy
This question is looking for legal (ie FAR) answers versus good
judgement.
Can anyone point me at the accuracy requirements for typical glider
instruments such as airspeed, altimeter, vario, and magnetic compass.
How much error is permitted before the instrument must be replaced or
repaired to keep the glider in an airworthy condition for VFR flight
in the US.
Old August 17th 07, 05:04 PM posted to rec.aviation.soaring
judgement.
in the US.
there are no inspection requirements for altimeter or airspeed for VFR
flight. IFR would require the static sytem be tested. compass has to
be adjusted to be within 5 degrees (i think) on any heading, and of
course the compass card has to be filled out showing the deviation at
various headings.
Old August 17th 07, 06:38 PM posted to rec.aviation.soaring
JS
flight. IFR would require the static system be tested.
You're being too reality-based.
Try telling that to the "I'm just covering my a__ and getting my
retirement" FAA inspector who constructed my last EXP operating
limitations. Had to get a pitot/static test done on a glider, then
have IFR forbidden in the op limits.
You probably need to be on LSD (or government payroll) to figure out
the rules any more.
Old August 17th 07, 07:02 PM posted to rec.aviation.soaring
the rules any more.
that would be like the fsdo maintenance inspector who was kind enough
to file an ntsb report for me after i had a non reportable incident?
yes it seems that sometimes the federalis dont know they're own
rules. sad.
the static check is a very common misconception. many mechanics
believe they are required for all aircraft. some market and IFR and a
VFR static check. ive always wondered what standards the VFR check is
held to.
Altimeter accuracy Jim Stewart Owning 18 May 15th 07 02:35 AM
Accuracy of GPS in Garmin 430/530 Will Instrument Flight Rules 110 May 29th 06 04:58 PM
GPS accuracy [email protected] Soaring 5 January 18th 05 06:29 PM
EGT Accuracy O. Sami Saydjari Owning 6 March 16th 04 10:53 PM
ILS instrument accuracy? Help...... TripFarmer Instrument Flight Rules 19 September 22nd 03 08:26 PM
