Tost brake bolt shears off - the answer
Old September 30th 07, 05:30 AM posted to rec.aviation.soaring
Jack Glendening
Default Tost brake bolt shears off - the answer
Nearly a month ago I reported on my Tost brake failure on landing. I
finally was able to get the plane to someone knowledgeable (Tom
Stowers) to look at it and the answer is that the brake was
incorrectly installed.
The axle spacer was placed on the wrong side of the hub, making the
hub off-center such that the anti-rotation bolt just barely extended
into the hole on the frame. I was able to get away with using it that
way for around 12 flights, since I never used the brake on landing,
only with light taps while taxiing the motorglider, The first time I
did have to use it on landing, it gave way. What I had thought was a
sheared off bolt was really the _end_ of the bolt with a small chip
taken off its edge (probably the tiny bit that extended into the
hole). So the bolt itself was not a problem and no photos of it are
needed.
Jack
Old September 30th 07, 02:16 PM posted to rec.aviation.soaring
Stealth Pilot[_2_]
On Sat, 29 Sep 2007 20:30:27 -0700, Jack Glendening
needed.
Jack
digital cameras are gods gift to dismantling parts.
take lots of photos as you dismantle. you'd be surprised at how often
a photo of something has the answer to a problem sitting in the
background.
Stealth Pilot
Tost brake bolt shears off Jack Glendening[_2_] Soaring 25 September 10th 07 11:15 PM
FS Tost E85 Release scooter Soaring 0 March 7th 06 03:31 AM
FS Tost E85 Release scooter Soaring 0 November 22nd 05 02:11 AM
TOST E85 RELEASES [email protected] Soaring 2 March 6th 05 05:21 PM
Tost release on L-19? Roy Bourgeois Soaring 2 November 29th 04 11:24 PM
