Quieting a gasoline driven compressor
Old October 14th 07, 12:27 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default Quieting a gasoline driven compressor
In the last 6 month's I've rescured a gasoline-driven air compressor.
It gives ma 125PSI and a volume that seems to fit my needs
(translation - so far, so good); unfortunately it's LOUD. I replaced
the muffler on the 5.5 hp Honda engine but it's still LOUD.
Short of putting it in an insulated box, or converting it to electric,
anyone have any ideas how I might quiet it? - Mike
Old October 14th 07, 02:31 PM posted to rec.aviation.homebuilt
Vaughn Simon
"Michael Horowitz" wrote in message
It would probably be too loud even if it had an electric motor,
particularly if the compressor is of the light weight, oiless variety. An
intake muffler on the compressor may help a bit, but the fact is that
compressors are loud and engines tend to be even louder, even with good
mufflers. I am afraid that there is no "magic bullet" here. When I built my
generator shed in my back yard (20 feet away from the house to manage the din) I
buried an air hose so that my compressor could also be banished out there.
Vaughn
Old October 14th 07, 04:58 PM posted to rec.aviation.homebuilt
John Ammeter
Either build a small insulated building with good ventilation for the
gas engine or move it to a distant location. Probably shouldn't move it
next to your neighbors bedroom, though...
I've got my Honda 6.5 KW generator in a small shed next to my garage.
When I use it (during storm power outages) I open the door (which faces
away from my house) and start it up. I've got a box fan inside the shed
which I use to help keep the shed "ventilated". That helps with cooling
of the engine plus keeps the exhaust gases out of the shed.
The "noise" from the generator is virtually non-existant... I can't
hear it in the house and none of the neighbors can hear it at all. On
the other hand, I CAN hear the generator from one neighbor who is at
least 600 feet away from me... Luckily, he's just bought a water cooled
Honda also so this winter it should be a lot quieter here..
John
Old October 14th 07, 08:00 PM posted to rec.aviation.homebuilt
jerry wass
John
the muffler on the 5.5 hp Honda engine but it's still LOUD. Short of
Plumb the exhaust straight UP !! with or without muffler It will be
nearly inaudible--try to get about 8 ft vertical. Jerry
Old October 14th 07, 08:07 PM posted to rec.aviation.homebuilt
jerry wass
it next to your neighbors bedroom, though...
faces away from my house) and start it up. I've got a box fan inside
the shed which I use to help keep the shed "ventilated". That helps
with cooling of the engine plus keeps the exhaust gases out of the shed.
cooled Honda also so this winter it should be a lot quieter here..
John
A noisy intake can be quieted the same way but you will have to install
a horizontal run that can be drained of rainwater.
Battery-Driven Tanis Marco Leon Piloting 30 February 4th 07 11:39 AM
Pump driven prop???? Montblack Home Built 5 May 19th 06 11:21 PM
Engine driven fuel pump necessary with gravity feed tank?? Lycoming RonLee Home Built 2 May 8th 05 06:10 PM
Question for computer whizzes-IPAQ driven by Flight Simulator? Stewart Kissel Soaring 0 January 3rd 05 03:45 AM
For Sale: Propellor Governor Drive Adapter with Driven Gear John Ammeter Home Built 0 February 1st 04 09:11 PM
