Wiring a Sailplane
Old December 11th 07, 05:34 AM posted to rec.aviation.soaring
Travis Beach
Default Wiring a Sailplane
Well got everything plumbed the other day adn need
to wire the entire electrical system...not a whole
lot to do really
New 12v 9.0 amp battery
5 and 3 amp Klixon Breakers for the Tasman and the
Microair 760
Aux. Power source Car Cig type plug-in
Bus Bar
Master Switch
PTT Switch
Microphone and speaker
In-line fuses
Anyone out there got any sage advice? Drawings of simple
wiring diagrams they can email me or links to sites?
Wiring, Seals, W&B, Annual and FLY...
Thanks...
Beach
Old December 11th 07, 08:33 PM posted to rec.aviation.soaring
Henryk Birecki
One thing to keep in mind is not to skimp on wire size. Use 14 gage or
lower for battery to panel wiring. I'd fuse each instrument separately
if feasible, not necessarily on panel. Keep speaker far away form
compass.
Cheers,
Henryk Birecki
lot to do really
Microair 760
Bus Bar
Master Switch
PTT Switch
In-line fuses
Thanks...
Beach
Old December 12th 07, 04:58 PM posted to rec.aviation.soaring
ContestID67
compass.
Gauges of wires can always be confusing because as the gauge number
goes down, the physical size of the wire (and its current carrying
capability) increases. Thus gauge #1 is much, much larger in diameter
than gauge #26. Normal household power wiring is 12-14 gauge.
Speaker wired tends to be in the 18-20 gauge range.
So when Henryk says "Use 14 gauge or lower for battery to panel
wiring." he is saying to use a lower gage number. Generally I would
have said "Use 14 gauge or higher for battery to panel wiring.".
My guidelines for wiring.
12 to 14 gauge - Main power lead from battery to distribution block
16 to 18 gauge - Power lead from distribution block to individual
devices
18 to 20 gauge - Speaker wiring
20 to 26 gauge - Control wires such as push-to-talk, air brake
switch, etc
Good luck, John
Old December 11th 07, 09:57 PM posted to rec.aviation.soaring
rlovinggood
Beach,
I was having a bit of electrical problems with my ship. Why? Because
I wired it.
Last winter, I took it to an avionics shop. They did a great and
professional job. They ripped out all that I had done and did it the
right way. They removed my fuses and installed circuit breakers. I
don't know the type or voltage drop across them. Although I had a
fuse at the battery, they installed one right at the battery connector
on the "ship" side of the connector rather than on the battery side.
Tefzel (sp?) wiring all around, including the radio speaker which had
been just regular old lamp cord. For removing the panel easily, he
installed a "cannon plug" where, with one quick twist, the plug is
loosened and all electrical connections (ok, I think I still need to
go to the back side of the Cambridge 302 and disconnect the
thermocouple and the gps antenna cable) are apart. Very nice!
The glider is Experimental, but I don't think the avionics shop did
anything different because of that.
Since then, I haven't had complaints that my radio sounded bad. I
guess enough volts are making their way between battery and panel to
keep everything happy.
Ray Lovinggood
Carrboro, North Carolina, USA
Old December 12th 07, 06:27 PM posted to rec.aviation.soaring
Cats
On Dec 11, 5:34 am, Travis Beach
lot to do really
Microair 760
Bus Bar
Master Switch
PTT Switch
In-line fuses
Thanks...
Beach
A further thought. Do it so the panel is easy to remove - you can get
Winter 'fast' connectors for the pneumatics, think about how the
electrics are connected as well to make it easy to do.
Old December 12th 07, 06:41 PM posted to rec.aviation.soaring
Marc Ramsey
In my experience (and of others I know), these Winter pneumatic
connectors have a tendency to leak after a few years. I use standard
inline connectors along with short pieces of tubing which get replaced
every time I remove an instrument or the entire panel. Nearly as easy,
and no problem with leaks...
Marc
Old December 12th 07, 07:16 PM posted to rec.aviation.soaring
bumper
"Marc Ramsey" wrote in message news:fjpa09
In my experience (and of others I know), these Winter pneumatic connectors
have a tendency to leak after a few years. I use standard inline
connectors along with short pieces of tubing which get replaced every time
I remove an instrument or the entire panel. Nearly as easy, and no
Marc
I use a short length of silicone rubber tubing (available at McMaster-Carr)
to connect to the instruments. Silicone rubber retains its elasticity,
resists ozone and weathering, so doesn't leak. It's also easy to get on and
off.
bumper
zz
Minden
Old December 12th 07, 07:29 PM posted to rec.aviation.soaring
Marc Ramsey
off.
I used to use silicon rubber for the short pieces, but elasticity also
allows for increased possibility of kinks and other restrictions in
flow. I feel more comfortable these days using fresh pieces of Tygon
tubing...
Marc
Old December 12th 07, 08:08 PM posted to rec.aviation.soaring
Bob Kuykendall
This is fun! Can we do this every year, right before the "silicone in
wax inhibits repair bonding" thread?
Thanks, Bob K.
Old December 12th 07, 10:18 PM posted to rec.aviation.soaring
Tim Taylor
Thanks, Bob K.
But it is only nine days to till the winter solstice, and we haven't
bashed the PW-5's yet (then again the Diana might be the new PW-5).
Wiring diagram for mic? Gary G Home Built 5 November 3rd 05 03:21 PM
Q about mic wiring ken ward Soaring 2 May 31st 05 10:33 PM
Wiring KX 175 TSO Tore B. General Aviation 0 May 6th 04 10:02 PM
wiring a mic plug S Green Owning 2 February 8th 04 11:28 PM
Wiring KDR-510 Chad Lemmen Owning 3 September 16th 03 02:03 PM
