Cobra wheel base outer dimension needed
Old January 24th 08, 03:00 AM posted to rec.aviation.soaring
Barny
Default Cobra wheel base outer dimension needed
Looking for the width of a 15m single seat Cobra trailer from tire
outside to tire outside to see if it will fit on a flat bed trailer
6'-8" wide. Cobra is 1998. Trying to arrange transport across the
county. Thanks, ~Barny
Old January 24th 08, 04:33 PM posted to rec.aviation.soaring
JJ Sinclair
6'-8" wide. *Cobra is 1998. *Trying to arrange transport across the
68" from tire to tire on my 1999 Cobra.
JJ
Old January 24th 08, 06:01 PM posted to rec.aviation.soaring
Richard[_1_]
My 1980s vintage Cobra measures 60" wide but it is much longer than
JJs.
Richard
www.craggyaero.com
Old January 24th 08, 09:23 PM posted to rec.aviation.soaring
JJ Sinclair
JJ
My 1980s vintage Cobra measures *60" wide but it is much longer than
JJs.
Richardwww.craggyaero.com
Soooo, I got 8 inches more than you!.........from a Ron White skit; Do
you want to touch bottom or fill up the sides?
:) JJ
Old January 25th 08, 12:54 AM posted to rec.aviation.soaring
Barny
Thanks JJ & Richard, looks like it will fit on the flatbed. I won't
comment on your length/girth battle........
Old January 25th 08, 06:59 PM posted to rec.aviation.soaring
Kloudy via AviationKB.com
JJ
My 1980s vintage Cobra measures Â*60" wide but it is much longer than
JJs.
:) JJ
now we'll probably start hearing from the Nimbus drivers about length. O_
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...aring/200801/1
Avionic trailer wheel needed qflyer1 Soaring 6 December 7th 06 03:30 PM
Tail skid with wheel needed [email protected] Soaring 1 May 31st 05 07:13 PM
1-26 Dimension Needed Mark Zivley Soaring 3 February 7th 05 02:16 PM
US source for wheel on the tongue of Cobra trailer? Mark Zivley Soaring 3 January 18th 05 03:51 AM
E2-C wheel bearings needed CaptAro Restoration 1 July 19th 03 04:32 AM
