Emergency and Discipline
Old February 29th 08, 05:33 PM posted to rec.aviation.piloting
Ol Shy & Bashful
Default Emergency and Discipline
If you are faced with a full blown emergency such as an engine
failure, what are you going to do?
Open ended question to generate some more conversation and
discussions. In my more than 50 years of aviation, I've had at least
18 actual emergencies and survived them all. Only one resulted in
physical injury and that was more than 40 years ago.
It is disconcerting to read the modern aircraft manuals (civilian) and
see most of it relates to shutting down the engine/s and heading for a
landing area rather than dealing with the emergency and keeping the
aircraft flying if possible.
Anyone want to hazard a guess at the major number of engine failure
causes?
Ol S&B
Old February 29th 08, 06:24 PM posted to rec.aviation.piloting
Jim Stewart
causes?
Here's what my instructor and I have been practicing..
If low, establish glide, secure engine, pick a spot
and land, flaps 40 and full stall if possible.
If high, establish glide, check fuel valve, try
restarts, throttle open, choke open, choke closed,
mag 1, mag 2, anything else you can think of...
If no luck, secure engine, look for field within gliding
distance. If developed airfield, call for priority and
land. If off-field, call 121.5, pick spot and stick
to it and land, flaps 40 and full stall. If terrain
is hostile, decrease airspeed, point plane at best
place and pull chute.
Your input is always appreciated.
Old February 29th 08, 07:42 PM posted to rec.aviation.piloting
WingFlaps
failure, what are you *going to do?
causes?
distance. *If developed airfield, call for priority and
land. *If off-field, call 121.5, pick spot and stick
to it and land, flaps 40 and full stall. *If terrain
I'd say, after getting the glide started, FMOST checks, recheck trim
for best glide, establish landing area, plan approach, squark 7700,
MAYDAY on working frequency or 121.5, passenger brief, EPIRB, secure
engine, masters off after no further use for electrical power. Land
the plane (? chute) and seek out a telephone -but if in the
wilderness, prepare for survival and if the plane survived, check the
EPIRB is transmitting. If you see/hear a plane try the VHF. Look after
the passengers. Start a fire (sufficiently away from the plane). I've
probably forgotten something...
Cheers
If terrain were hostile, you might want to consider location a bit
before you pull that chute handle by the way.
Old February 29th 08, 07:58 PM posted to rec.aviation.piloting
Gig 601XL Builder[_2_]
If you are going to pull chute the handle for an engine out over any
other than very hostile terrain please remind me not to fly with you.
Old February 29th 08, 10:23 PM posted to rec.aviation.piloting
WingFlaps
On Mar 1, 8:58*am, Gig 601XL Builder
I agree, that's why I said "land the plane (? chute)" Of course if the
engine out means it's really fallen out of the plane I'd like that
chute availability...
Cheers
Old February 29th 08, 10:27 PM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
"Gig 601XL Builder" wrote in message
If you are going to pull chute the handle for an engine out over any other
Then there was the student pilot flying solo who ran out of gas on final,
turned away from the airport, and jumped out (with a 'chute)...
Really.
I ran into that in the NTSB accident reports while looking for something.
Geoff
Old March 1st 08, 03:24 AM posted to rec.aviation.piloting
I'd like to read that one. Do you recall what you searched for to find
it?
Old March 1st 08, 01:56 AM posted to rec.aviation.piloting
LWG
One less thing for me to remember...
pull chute.
Old February 29th 08, 07:14 PM posted to rec.aviation.piloting
WingFlaps
Aviate, navigate communicate? I'd guess the number one cause was the
pilot not doing something like make sure of adequate fuel.
Cheers
Old February 29th 08, 07:43 PM posted to rec.aviation.piloting
kontiki
causes?
Ol S&B
I would say fuel starvation or fuel mismanagement would be the #1.
But given that a lapse of following procedures and/or FAA regulations
was the precipitating factor, the next thing in line is bad decision
making and problem resolution skills. Too often an emergency that
is survivable becomes a fatal accident because the pilot was not
prepared in skill set or mindset to deal with it.
But this is why we train and continue to train so we have the skills
and methods firmly ingrained to deal with emergencies. Most accidents
are due to some sort of pilot error (poor decision making?) or failure
to maintain control of the aircraft (cockpit management?).
Emergency Dan Luke Piloting 57 April 12th 06 02:01 PM
WTB: emergency parachute knightglider Soaring 0 August 13th 04 09:12 PM
Emergency Procedures RD Piloting 13 April 11th 04 08:25 PM
Not an emergency??? William W. Plummer Instrument Flight Rules 14 December 26th 03 06:28 AM
Former head of cadet discipline says she never saw a 'true rape' Otis Willie Military Aviation 0 September 11th 03 08:37 PM
