MSFS2004 question
Old March 13th 08, 01:01 PM posted to rec.aviation.homebuilt
Dick[_1_]
Default MSFS2004 question
where can I get the steps involved with putting a zipped 601hd flight sim
download to my MSFS 2004? thanks.
Old March 13th 08, 01:17 PM posted to rec.aviation.homebuilt
Gig 601XL Builder[_2_]
One of the flight sim newsgroups.
Old March 13th 08, 05:46 PM posted to rec.aviation.homebuilt
www.zenithair.com has a link to flight sim downloads of the 601. It's
a pretty fun little sim plane that "handles" well in the simulator,
ie, is not twitchy or weird or otherwise hard to control with a
joystick/rudder pedals.
Old March 13th 08, 06:18 PM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
I think that's not really an answer to the question.
As I read the original post, it seems that one of these files has been
downloaded, but that now the O/P is unsure how to install it.
My answer: most of these files are compressed archives. Uncompress it,
then check for a README file or such. Often, there is a directory
"CH601" (or whatever) in the archive, that you can simply drag and drop
into place in your FS directory tree. No other action is required.
If the designer created a separate instrument panel, it may be necessary
to copy some files into the GAUGES directory.
Good luck!
Old March 13th 08, 09:45 PM posted to rec.aviation.homebuilt
There's one problem with that sim model of the 601XL that is on Zenith's
site. If you stall it the engine stops running.
God I hope the real one doesn't do that but if it does I will let you
know.
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
*Released 256 Command FA Voice Recognition Profile MSFS2004 Sonar5 Simulators 1 December 20th 04 06:25 AM
VFR flight question (MSFS2004) Vic Baron Simulators 3 September 1st 03 04:03 AM
Notebook PC Configuration for MSFS2004 Paul H. Simulators 0 July 18th 03 11:21 PM
