Fuselage weight, wood vs:tube
Old April 23rd 08, 03:18 PM posted to rec.aviation.homebuilt
Griff
Default Fuselage weight, wood vs:tube
Several years ago I started building a RagWing Special. I built
everything but the fuselage,when the facts that it tended to fly tail
low,and would not make UL weight stopped me. Graham Lee (RIP) in a
post ,suggested the tail low attitude was caused by the lack of
downthrust,problem solved. The weight issue could be solved by a steel
tube fuselage.Any thoughts on a steel tube vs:wood weight advantage on
a smaller ac ?
Thanks
Old April 23rd 08, 07:53 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
a smaller ac ?
Thanks
That sounds more like a rigging issue.
If the tail "flies low", then the wings probably don't have enough
angle of incidence.
Richard
(remove the X to email)
Now just why the HELL do I have to press 1 for English?
John Wayne
Aluminum vs Wood vs Hybrid fuselage steveukman Home Built 2 August 3rd 06 03:04 PM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
why isn't there composite tube fuselage design? Shin Gou Home Built 13 February 17th 05 03:28 AM
Who can identify this tube frame aircraft fuselage? Rob de Bie Home Built 5 January 13th 05 09:45 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
