Feds Want to Equipe Gliders With Transponders and Radios
Old April 28th 08, 01:10 PM posted to rec.aviation.piloting,rec.aviation.soaring
F. Baum
Default Feds Want to Equipe Gliders With Transponders and Radios
On Apr 27, 1:15*pm, Larry Dighera wrote:
On Sun, 27 Apr 2008 11:06:21 -0700 (PDT), "F. Baum"
Just to clarify, The FAA does not classify a glider as an airplane so
this has nothing to do with the exemption. The press release is poorly worded.
I believe this is the NTSB Safety Recommendation Letter dated March
31, 2008:
Gee, thanks. I was aware of this. I was trying to point out that this
has nothing to do with vintage planes without an engine driven
electrical system. You dont normaly see a champ flying wave at 16000
MSL. The manor in which sailplanes are flown is what makes this an
issue.
Old April 28th 08, 06:16 PM posted to rec.aviation.piloting,rec.aviation.soaring
Larry Dighera
On Mon, 28 Apr 2008 05:10:42 -0700 (PDT), "F. Baum"
wrote in
31, 2008:
issue.
While the NTSB Safety Recommendation Letter dated March 31, 2008 seems
to be a request for the FAA to remove the glider exemption from the
regulation(s) regarding mandatory transponder operation, it does also
mention aircraft manufactured/certified without electrical systems.
One wonders why the NTSB would only "close the door" half way on this
issue.
Old May 1st 08, 03:26 PM posted to rec.aviation.piloting,rec.aviation.soaring
Steven P. McNicoll[_2_]
"Larry Dighera" wrote in message
issue.
Perhaps it is because the NTSB recognizes that aircraft
manufactured/certified without electrical systems are not operated in the
same manner as gliders and are thus not an issue.
Feds Want to Equipe Gliders With Transponders and Radios Larry Dighera Soaring 67 May 11th 08 12:20 AM
Feds Want to Equipe Gliders With Transponders and Radios Larry Dighera Piloting 155 May 10th 08 02:45 PM
Feds Want to Equipe Gliders With Transponders and Radios Larry Dighera Soaring 12 May 1st 08 03:42 PM
Feds Want to Equipe Gliders With Transponders and Radios Larry Dighera Soaring 0 April 28th 08 04:22 AM
Transponders and Radios - USA Ray Lovinggood Soaring 1 February 27th 04 06:10 PM
