Tests with Turdulators on Cherokee II
Old June 2nd 08, 05:00 AM posted to rec.aviation.soaring
Default Tests with Turdulators on Cherokee II
Today when I got the glider out of the hangar I noticed that it had
been graced with Avian Turdulators. Ive heard a lot about this
revolutionary aerodynamic breakthrough so i thought id try it out. I
did take a hose and knock them down pretty flush with the wing
planform so that they only did their magic on the boundary layer
flow. It seemed to work out pretty well during most of my flight (see
Wood over Iowa thread), but late in the day I was not impressed as I
landed out about 5 miles from home. So much for these 'inspired by
nature' performance enhancing devices...
Old June 2nd 08, 02:59 PM posted to rec.aviation.soaring
Ian Cant
I think the performance is noticeably affected by the differing thermal
characteristics of dark vs light colors. On glass birds, the turbulators
appear as yellow or red objects against a white background, while on my
1-26 they are white against the yellow/red backgrounds. Also, on glass
they mainly generate themselves in-flight and have to be removed
afterwards, while on the 1-26 they appear overnight and may be removed
pre-flight.
Despite suggestions from other observers, I cannot verify that while on
glass they cluster on the leading edges but on Schweizers thay prefer the
trailing edges.
Ian
Old June 2nd 08, 04:20 PM posted to rec.aviation.soaring
Bill Daniels
"Ian Cant" wrote in message
Snip...
trailing edges.
Ian
I know Schweizers can get bird strikes from the rear - but bugs? Wow, you
guys can fly slow.
Speed tests SN Home Built 0 August 24th 05 08:55 PM
EMI, EMC, tests Fritz General Aviation 2 October 20th 04 11:00 PM
Compression Tests Doug Aerobatics 4 March 27th 04 05:29 AM
Key tests for new jet set for April Otis Willie Military Aviation 0 March 25th 04 11:12 PM
VOR tests Hilton Instrument Flight Rules 12 August 20th 03 10:33 AM
