I have inherited an EW Avionics D type recorder with the glider I am now
flying. But over the last few months even though I have taken it flying with me quite a few times and it seems to work OK. I have used the EW uploader to save the traces so I know the cable connection works, but I have never actually been able to read the resulting data from a computer I understand (and I find this rather disappointing) you have to buy additional software over and above what you first paid to make full use of the recorder itself. There is however a simple MS-DOS programme that you can use instead. But every time I try to connect up I get the message ‘put it in PRT mode by pressing the PRT key’. Does anyone have any idea what is going wrong or have I missed something here |
At 20:55 12 August 2008, Douglas Logan wrote:
I have inherited an EW Avionics D type recorder with the glider I am now flying. But over the last few months even though I have taken it flying with me quite a few times and it seems to work OK. I have used the EW uploader to save the traces so I know the cable connection works, but I have never actually been able to read the resulting data from a computer I understand (and I find this rather disappointing) you have to buy additional software over and above what you first paid to make full use of the recorder itself. There is however a simple MS-DOS programme that you can use instead. But every time I try to connect up I get the message ‘put it in PRT mode by pressing the PRT key’. Does anyone have any idea what is going wrong or have I missed something here It's been a while since I had a 'D' but I don't think the DOS program works on anything later than Windows '98. This may or may not work: Right click on your .ewt flight file, open with Notepad. Then File Save as xxx.igc It's the .igc that's important. Use this site: http://www.gpsvisualizer.com/gpsbabel/ to convert the FAI/IGC track file to a Google Earth KML and view the result in Google Earth. good luck, Edward |
Douglas,
For the past three years I have been using the EW Windows Uploader. It copies the files from the EW Model D and coverts the EW format to IGC. You can also upload the files from your EW using SeeYou. The EW Windows Uploader is free and can be downloaded from http://www.edavies.nildram.co.uk/ew/...dows-uploader/ I am currently using Version Number 0523X. The NavITer (SeeYou) program ConnectMe can also be downloaded free. http://www.naviter.si/products/connectme.php?Itemid=62 Both these programs work well. Wayne HP-14 "6F" http://www.soaridaho.com/Schreder "Douglas Logan" wrote in message ... I have inherited an EW Avionics D type recorder with the glider I am now flying. But over the last few months even though I have taken it flying with me quite a few times and it seems to work OK. I have used the EW uploader to save the traces so I know the cable connection works, but I have never actually been able to read the resulting data from a computer I understand (and I find this rather disappointing) you have to buy additional software over and above what you first paid to make full use of the recorder itself. There is however a simple MS-DOS programme that you can use instead. But every time I try to connect up I get the message 'put it in PRT mode by pressing the PRT key'. Does anyone have any idea what is going wrong or have I missed something here |
You can do a google search on "ewtoigc" and see if it suits your
needs. Henryk Birecki Douglas Logan wrote: I have inherited an EW Avionics D type recorder with the glider I am now flying. But over the last few months even though I have taken it flying with me quite a few times and it seems to work OK. I have used the EW uploader to save the traces so I know the cable connection works, but I have never actually been able to read the resulting data from a computer I understand (and I find this rather disappointing) you have to buy additional software over and above what you first paid to make full use of the recorder itself. There is however a simple MS-DOS programme that you can use instead. But every time I try to connect up I get the message ‘put it in PRT mode by pressing the PRT key’. Does anyone have any idea what is going wrong or have I missed something here |
On Tue, 12 Aug 2008 20:55:10 +0000, Douglas Logan wrote:
I have inherited an EW Avionics D type recorder with the glider I am now flying. But over the last few months even though I have taken it flying with me quite a few times and it seems to work OK. I have used the EW uploader to save the traces so I know the cable connection works, but I have never actually been able to read the resulting data from a computer I understand (and I find this rather disappointing) you have to buy additional software over and above what you first paid to make full use of the recorder itself. As others have said, the Windows downloader is available for free from EW Avionics http://www.ewavionics.com. It can be used to set the clock in the model D, change the sampling rate, etc. as well as downloading logs and clearing the logger's memory. Once the logfile has been downloaded and saved to disk the logger's job is done. What, if any, program you choose to use after that is up to you: - your web browser (Opera or Firefox are better than IE and both are free) is sufficient to post the flight to the BGA league table or OLC. - at a contest the organisers should have the software they require to download the log and score the flight. - if you want to view the trace and analyse your flight you'll have to get hold of a suitable program, e.g. GPLIGC (Open Source) or SeeYou (commercial). -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
IGC-approval of two new types of recorder | Ian Strachan | Soaring | 0 | June 15th 08 05:41 PM |
In flight recorder | Lou | Piloting | 23 | March 24th 07 12:45 AM |
EW B-Model flight recorder | BDS | Soaring | 12 | August 19th 06 04:39 PM |
GA cockpit and radio recorder | Ronnie | Instrument Flight Rules | 15 | April 20th 06 12:10 AM |
IGC-approval for LXN LX7007F recorder | Ian Strachan | Soaring | 0 | March 17th 06 07:55 PM |
