Low pressure limit in Acetylene tank?
Old August 13th 08, 07:33 PM posted to rec.aviation.homebuilt
mhorowit
Default Low pressure limit in Acetylene tank?
how low do you let your acetylene tank get before getting a refill? -
Old August 13th 08, 07:41 PM posted to rec.aviation.homebuilt
Rocky
0 PSI
Old August 13th 08, 08:32 PM posted to rec.aviation.homebuilt
On Aug 13, 12:41 pm, Rocky wrote:
0 PSI
Oxyacetylene rigs should have anti-backflash check valves at
the torch end of the hoses so that oxygen can't go back up through the
acetylene hose and into an acetylene tank that's at zero psi. If those
valves aren't there the operator shouldn't let the tank pressure fall
so low that oxygen pressure could do that. Oxygen in an acetylene tank
is a bomb, of course. Acetylene is already unstable enough without
that.
Dan
Old August 14th 08, 01:53 AM posted to rec.aviation.homebuilt
John[_17_]
As long as you have check valves in the lines, to the point where there
is not enough pressure to sustain the 3-5 psi regulator setting at the
flow demand of the torch.
Acetylene is only unstable if in the gaseous state ABOVE 15 psi.
John
Old August 25th 08, 05:01 AM posted to rec.aviation.homebuilt
dpilot
On Aug 13, 8:53 pm, John wrote:
John
Paul Mee, the lead welder for Aeronca (sp) says never weld with less
than 100 pounds
if you want a good weld.
He said you ain't got enough heat. with less than 100 pounds.
I suppose if you just wanted to heat up something to bend it or
whatever, any psi would be ok
JimV.
Old August 25th 08, 10:47 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Sun, 24 Aug 2008 21:01:04 -0700 (PDT), dpilot
John
than 100 pounds
JimV.
what may cause the low pressure limitation is the way acetylene is
stored in the tanks. I am told that it is in solution with some
solvent - acetone I think - and that it is not just a gas as in the
case of oxygen or argon. more like a soda pop with gas disolved in the
fluid to make it stable/non explosive in the bottle.
take the pressure down too far and you may not be getting acetylene as
the gas.
ask your distributor for the details though. this was related to me
second hand.(the guy was getting stuck into me in a model engineers
meeting)
Stealth Pilot
(paul mee is in the USA isnt he? shouldnt that be $200 or did you mean
psi :-) )
Old August 25th 08, 02:27 PM posted to rec.aviation.homebuilt
Anyolmouse
"mhorowit" wrote in message
| Mike
My supplier charges extra if you let it get below 100lbs or so. They say
they have to pull a vacuum on the cylinder and then recharge it when it
is returned too low. (I own the cylinders)
Anyolmouse
---- Posted via Pronews.com - Premium Corporate Usenet News Provider ----
http://www.pronews.com offers corporate packages that have access to 100,000+ newsgroups
Tank pressure for Speedaire compressor? Michael Horowitz Home Built 7 May 21st 08 11:05 PM
limit of trim = limit of travel? Mxsmanic Piloting 251 May 11th 08 07:58 PM
Saturn V S-IC-T (static test stage) fuel tank assembly is mated to the liquid oxygen (LOX) tank 6416666.jpg [email protected] Aviation Photos 0 April 12th 07 01:33 AM
The Sky is Their Limit [email protected] Soaring 7 November 13th 06 02:44 AM
Positive Tank Pressure Greg Esres Owning 6 April 29th 04 11:44 AM
