Collins TDR-950 connector pin numbering
Old December 9th 08, 12:40 AM posted to rec.aviation.homebuilt
MaxGain
Default Collins TDR-950 connector pin numbering
Anyone know how the pins on a TDR-950 transponder connector are
numbered? As you are looking at the connector from the back of the
unit, left to right? Right to left?
Thanks.
Old December 9th 08, 02:27 AM posted to rec.aviation.homebuilt
Morgans[_2_]
"MaxGain" wrote in message
Thanks.
Do you have the pinout with the function of each pin?
It should be a simple task, to check around to find continuity between the
ground pin and the case, and that location will tell you which way it is
oriented. (unless it has the ground exactly in the middle of the plug g)
Old December 9th 08, 04:25 PM posted to rec.aviation.homebuilt
Tri-Pacer[_2_]
http://www.bomar.biz/download.php?0....nload_name.ASC
Check here
Old December 10th 08, 02:38 AM posted to rec.aviation.homebuilt
MaxGain
On Dec 9, 11:25*am, "Tri-Pacer" no wrote:
Anyone know how the pins on *a TDR-950 transponder connector are
numbered? *As you are looking at the connector from the back of the
unit, left to right? * Right to left?
Check here
Thanks Tri-Pacer, good site.
Max
Pin out Collins VHF-251 TSO Scott D Owning 2 October 27th 10 01:12 AM
Help Channeling a collins GLS-350 Sandy Barber Owning 0 January 17th 07 11:55 PM
Collins GLS 350 info Sandy Barber Home Built 0 December 29th 06 12:05 AM
Runway Numbering - Radio Procedure Daniel L. Lieberman Piloting 41 October 31st 05 06:41 AM
Collins Radio Travis Marlatte Owning 14 February 19th 04 05:07 PM
