Loose Bolts Ground V-22 Ospreys; Four Aircraft in Iraq Will NeedFixes
Old March 26th 09, 09:56 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jack Linthicum
Default Loose Bolts Ground V-22 Ospreys; Four Aircraft in Iraq Will NeedFixes
On Mar 26, 3:58*am, Kerryn Offord wrote:
Matt Wiser wrote:
Then explain its record in Iraq and Afghanistan so far. No combat losses or
crashes in-country. Like I said, if you have an alternative platform to
replace the H-46s, let's hear it. Otherwise, either get on board or get out
of the way.
doing what kind of operations at what kind of tempo..
last we heard (SMN) it was doing the mail runs.. and running through
their engines at a high rate of knots...
As for alternatives.. any number of proper helicopters... Things that
can carry the same cargo with a third of the power requirements.. And
can fly quite easily with a slung load... (If the V-22 fly with a slung
load you'd be better off using helicopters... they're only any good if
you can fly with internal cargo only.. and even then it gets a bit
cramped....
First crash with real troops on board and it gets on the "history"
list. One of the concepts of the V-22 was its ability to switch from
vertical to horizontal. The loose bolts seem to suggest that might not
work every time.
Old March 26th 09, 10:38 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Curt
Default Loose Bolts Ground V-22 Ospreys; Four Aircraft in Iraq Will Need Fixes
"Vincent Brannigan" wrote in message
vaughn wrote:
"Jack Linthicum" wrote in message
Compromising control of the rotor sounds like a fatal crash to me. I
have seen military blogs that say that all of the production must be
finished and accepted before the first major accident can occur.
Wishing or making sure?
This is the type of stuff that happens with any new aircraft. We
"learn by doing". With something as complex and as "different" as the
Osprey, we will probably see a significant list of these issues. And
yes, some of them will probably cause accidents before the learning is
all over.
Vaughn
"new" ? any idea how long this sucker has been teething?
First flight was 19 March 1989
20 years ago !!!!!!!!!!!!!!!!!!!!!
Keep making excuses for the turkey
Vince
I guess this means the C-130 a turkey as well. 'course, it's only been
flying since 1956.
"Inspections of C-130 Hercules cargo aircraft ... are turning up cracks in
the nuts and bolts used to attach the wings to the planes' fuselages. The
order to inspect the fleet came late Thursday after cracks were found in
some upper wing joint barrel nuts. As a result, the U.S. Air Force has
ordered that every C-130 in the nation's 600-plane fleet be checked, which
includes the older..."
Curt
KVPS
Old March 26th 09, 11:09 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jack Linthicum
have seen *military blogs that say that all of the production must be
* *This is the type of stuff that happens with any new aircraft. *We
"learn by doing". *With something as complex and as "different" as the
Osprey, we will probably see a significant list of these issues. *And
all over.
Vaughn
"new" *? *any idea how long this sucker has been teething?
Vince
I guess this means the C-130 a turkey as well. *'course, it's only been
flying since 1956.
Curt
KVPS
There is a discernible difference between a device that has been used
successfully for that 53 years and is now showing signs of that age
and a device which shows signs of age without being old.
Old March 26th 09, 11:39 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Peter Skelton
On Thu, 26 Mar 2009 02:21:41 -0400, "Raymond O'Hara"
"Matt Wiser" wrote in message
As long as it takes. The USMC has a habit of getting its way on
procurement,
so either get on board or get out of the way. Not to mention that it's
been
a number of years since the last crash (the one that had 19 Marines
killed),
and the aircraft has been tested, evaled, and tested again. If you've got
an
alternative aircraft to replace the H-46, let's hear it. If not, follow
above advice.
there comes a point when it's obvious the thing doesn't work as advertised.
the V-22 passed that 5 years ago.
the B-29 had no more than normal teething troubles and was soon enough
sorted out.
The development of the B-29 was long, expensive and difficult for
the time. There was a direct and urgent need that made it worth
the trouble. Under similar pressure the V-22 might have worked
two decades ago.
Peter Skelton
Old March 26th 09, 11:44 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Peter Skelton
Default Loose Bolts Ground V-22 Ospreys; Four Aircraft in Iraq Will Need Loose Bolts Ground V-22 Ospreys; Four Aircraft in Iraq Will Need
On Thu, 26 Mar 2009 02:56:45 -0700 (PDT), Jack Linthicum
of the way.
cramped....
work every time.
April 8, 2000
Peter Skelton
Old March 26th 09, 03:47 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Bill Kambic
On Wed, 25 Mar 2009 16:21:48 GMT, Vincent Brannigan
This is the type of stuff that happens with any new aircraft. We "learn
by doing". With something as complex and as "different" as the Osprey, we
will probably see a significant list of these issues. And yes, some of them
will probably cause accidents before the learning is all over.
Vaughn
A good friend of mine ditched an S-2E off Rhode Island in 1973 after
an elctrical system glitch was found. That system that failed had
been in Fleet Service in the S-2D, E, and G series.
We were still learning about the P-3 in late '70s and early '80s, more
than 20 years after fleet introduction.
I suspect every aircraft ever put into service surprises the users
from time to time.
Old March 26th 09, 06:17 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Matt Wiser
me. I have seen *military blogs that say that all of the
production must be finished and accepted before the first major
*accident can occur. Wishing or making sure?
*"learn by doing". *With something as complex and as "different"
as the Osprey, we will probably see a significant list of these
issues. *And yes, some of them will probably cause accidents
Vaughn
Vince
been flying since 1956. "Inspections of C-130 Hercules cargo aircraft
*... are turning up cracks in the nuts and bolts used to attach the
wings to the planes' fuselages. The order to inspect the fleet came
late Thursday after cracks were found in some upper wing joint barrel
*nuts. As a result, the U.S. Air Force has ordered that every C-130
in the nation's 600-plane fleet be checked, which includes the
older..."
the *suggestion was that this was a "This is the type of stuff that
happens with any new aircraft"
The C 130 is a quality control issue with a part
"Concerns surfaced March 5 about a particular brand of upper wing
joint barrel nuts used in C-130s to attach the wings to the fuselage.
* The barrel nuts supplied by one manufacturer were deemed "suspect"
* after routine inspections discovered a potential for stress fractures
* in the metal. As a result, the Pentagon mandated a fleetwide
* inspection of each plane's 26 barrel nuts and replacement of all nuts
* with the faulty design before the planes could fly again."
The V-22 Loose bolts are either a maintenance screw up or a design problem
Vince- Hide quoted text -
- Show quoted text -
Most likely the former. They're still finding occasional issues with
C-130s, P-3s, F/A-18s, etc. If you've got an existing helo that can
match the range, performance, and other requirements that the V-22
meets, name it. Otherwise, get on board or get out of the way.
Old March 26th 09, 06:35 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Jack Linthicum
Vaughn
Vince
older..."
Might recommend getting out of the way, V-22's greatest quality is
speed, an overrated quality in a combat situation.
Old March 26th 09, 08:17 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Peter Skelton
On Thu, 26 Mar 2009 15:11:06 GMT, Vincent Brannigan
me. I have seen military blogs that say that all of the
issues. And yes, some of them will probably cause accidents
Vaughn
Vince
older..."
the suggestion was that this was a "This is the type of stuff that
On what basis do you reject subspecification manufacture, and
improper original installation?
Peter Skelton
Old March 26th 09, 10:58 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Arved Sandstrom[_2_]
Matt Wiser wrote:
As long as it takes. The USMC has a habit of getting its way on procurement,
so either get on board or get out of the way. Not to mention that it's been
a number of years since the last crash (the one that had 19 Marines killed),
and the aircraft has been tested, evaled, and tested again. If you've got an
alternative aircraft to replace the H-46, let's hear it. If not, follow the
above advice.
[ SNIP ]
New CH-46's? I'm not being entirely facetious here...other folks
suggested this back in the '90's, although the idea would have been to
manufacture an improved CH-46.
One of our (any country, not just the US) biggest defense procurement
problems is whenever a weapons system or vehicle or
radio...whatever...starts getting old, we almost always feel the need to
design and build a *new* thing. I'll buy that concept for electronics,
but it's not obvious to me that if a truck fleet or a buy of helicopters
or rifles gets worn out, that we need to spend 10 or 20 years designing
entirely new ones.
AHS
KX-99 antenna BNC loose [email protected] Owning 1 April 10th 08 04:26 PM
"First Ospreys Land In Iraq; One Arrives After 2 Setbacks" Mike[_7_] Naval Aviation 50 November 30th 07 05:25 AM
Seaplane Base - 4 - Cut Him Loose-3.jpg (1/1) john smith[_2_] Aviation Photos 0 August 2nd 07 05:11 AM
I met US Navy aircraft during Iran-Iraq war Amir - Iranian F-4 pilot Naval Aviation 0 July 29th 07 08:02 PM
Metric Aircraft Nuts and Bolts John Scott Soaring 6 December 14th 05 08:54 PM
