bolt not coming undone on asw-15b mainwheel
Old April 1st 09, 05:13 AM posted to rec.aviation.soaring
Default bolt not coming undone on asw-15b mainwheel
Trying to change the tube out. There's 3 small 10 mm nuts on one
side. One of them came right off no problem. The other two, turn,
but the bolts spin with the nut! The backside of the bolt is inside
the wheel. The only one that came off, was just easy to unscrew.
If I can't reach inside and hold the backside of the bolt, then how
can I get these three bolts off to change the tire?
If anyone has done this, and I can send pictures to your email....then
shoot me a line at "liv2soar at yahoo dot com"
Thermals are here!
See you at cloudbase
Spam
Old April 1st 09, 11:28 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
To be accurate, you have NOTHING on one side of the wheel and a number of threads and nuts on the other? Is this right? And one is off OK, 2 are spinning?
If so, you may need to do some engineering.
Get a drillpress and a ring-spanner of the right size for the nut.
Hold the nut with the spanner and carefully drill the stud through the centre of the nut, use a small drill first as a pilot.
Be careful not to drill past the depth of the nut, into the hub.
It is probable that the nut will come undone before the drilling has finished.
Either way you will need new nuts and studs BUT- there must be a reason why the stud is turning, such as a broken keeper plate within the hub.
I am sure with knowledge of ASW-15 style of wheel someone can add to this post, do the above as a last resort.
bagger
Old April 1st 09, 02:31 PM posted to rec.aviation.soaring
Remove the brake assembly to expose the head of the 3 bolts.
JJ
Old April 2nd 09, 12:40 AM posted to rec.aviation.soaring
I decided to think OUTSIDE the box.
Here's what I came up with. Since I work for an airline, I just
brought the stuff to a mechanic friend today. Real simple. He said
watch this, and practically rebuilt the entire assembly, tire, brake
and all. Amazing how fast people can work on stuff when it's what
they do everyday for a living.
Easier and better solution!
Grob 103 AD note for bolt, USA [email protected] Soaring 2 March 2nd 09 05:47 PM
Tost brake bolt shears off Jack Glendening[_2_] Soaring 25 September 10th 07 10:15 PM
Bolt Head markings john smith Piloting 2 June 13th 05 02:23 AM
Bolt torque Neal Fulco Home Built 1 October 16th 04 06:57 AM
Prop bolt torque setting Whunicut Home Built 2 September 4th 03 12:12 PM
