Repacking wheel bearings
Old June 12th 09, 03:39 AM posted to rec.aviation.soaring
Ramy
Default Repacking wheel bearings
I can't find anything about repacking the bearings in the Cobra
trailer web site http://www.cobratrailer.com
Are the Cobra bearings sealed and don't need periodic repack?
Otherwise what is the general recomendation?
Ramy
Old June 12th 09, 04:59 AM posted to rec.aviation.soaring
Janus2k
"Like all new cars, COBRA-trailer uses compact bearings since they
are
available.With this bearings, there is no repacking, greasing or
adjusting needed or possible. This bearings are sealed and greased
for
lifetime.
When you open the grease cap on the axle, you will see a self
securing
all- metal nut ( Without any safety pin)
On older axles there is a crown-style nut and a safety pin through
nut and the axle stump. This bearings need to be repacked, greased
and
adjusted."
This is per Cobra/AS
Mark Mahan
2K
Old June 12th 09, 05:03 AM posted to rec.aviation.soaring
JS
The newer ones have sealed bearings. My last (1994) trailer didn't but
the current (1999) has them.
Komet trailer wheel bearings Dan[_6_] Soaring 7 February 9th 09 06:13 AM
US NPRM Parachute Repacking to 180 days Frank Whiteley Soaring 0 July 27th 07 01:48 PM
USA-NPRM on Parachute Repacking cycle comment period open. Frank Whiteley Soaring 1 May 26th 07 07:53 PM
Q about trailer wheel bearings Ken Ward Soaring 1 September 15th 06 02:40 AM
E2-C wheel bearings needed CaptAro Restoration 1 July 19th 03 04:32 AM
