Portable/back up transceiver
Old July 25th 09, 01:50 PM posted to rec.aviation.piloting
bobengr
Default Portable/back up transceiver
Looking to buy a protable/backup transceiver. Any recommendations?
Old July 25th 09, 09:58 PM posted to rec.aviation.piloting
Steve Hix
In article
I've got an Icom IC-A6 that's pretty nice.
Old July 25th 09, 10:04 PM posted to rec.aviation.piloting
jan olieslagers[_2_]
Steve Hix schreef:
In article
Same here. Don't know where you are but here in Continental Europe it's
often worth a train ticket to England to buy it there. Typically 400 €
vs. 200 GBP.
Mind you a true back-up must cover all radio-failures, meaning it should
not be powered from the aircraft power bus. But making sure the
batteries are fully charged is one more point on the already too long
pre-flight checklist.
Old July 25th 09, 10:32 AM posted to rec.aviation.piloting
Morgans[_7_]
"jan olieslagers" wrote in message
Steve Hix schreef:
In article
often worth a train ticket to England to buy it there. Typically 400 € vs.
200 GBP.
not be powered from the aircraft power bus. But making sure the batteries
are fully charged is one more point on the already too long pre-flight
checklist.
Buying the optional extra alkaline battery pack will make that point moot.
Old July 26th 09, 03:23 AM posted to rec.aviation.piloting
Private
"Morgans" wrote in message
Steve Hix schreef:
In article
vs. 200 GBP.
checklist.
And using rechargeable NiCad's in the 6xAA battery pack will save the
factory battery life (no need to use) and you can carry spare AA batteries
which will also probably fit your flashlight and other stuff.
My pilot shop has the Icom A6 for under $250 including the optional AA
battery pack and the headset adapter which is really expensive (~$75)
separately.
Happy landings.
Old July 26th 09, 04:27 PM posted to rec.aviation.piloting
RST Engineering - JIm
NiCads a
a. Horrible for the enviornment (that's the Cad part of NiCad)
b. Have a lousy self-discharge characteristic
c. Are relatively expensive.
NiMH a
a. Not too harmful of Mother Nature
b. Have a fairly decent self-discharge characteristic
c. Are relatively inexpensive (check out thomasdistributing.com)
You may also look into a LiIon pack, depending on which radio you buy. THey
are even better than NiMH.
"Private" wrote in message
Old July 26th 09, 10:10 PM posted to rec.aviation.piloting
Steve Hix
jan olieslagers wrote:
Steve Hix schreef:
In article
Central California.
often worth a train ticket to England to buy it there. Typically 400 ¤
vs. 200 GBP.
Now if I can just find the AC adapter ...
Old July 28th 09, 06:16 PM posted to rec.aviation.piloting
Ross
Steve Hix schreef:
In article
vs. 200 GBP.
I would not use rechargeable batteries, rather Alkaline batteries instead.
Regards, Ross
C-172F 180HP
Sold
KSWI
Old July 30th 09, 03:16 PM posted to rec.aviation.piloting
"Clark" wrote in message
Just a data point - I've been using the long-life hybride rechargeables
for
about a year now and find they give good service.
I don't use the older nickle metal hydride rechargeables at all anymore.
What is a "hybride" (sic) battery?
What color is a nickle? (Green, look it up. It is a woodpecker.)
Old July 28th 09, 06:14 PM posted to rec.aviation.piloting
Ross
If you get one, you better buy the headset adapter. Otherwise they are
almost worthless in the cabin, due to noise. I found that out and
quickly bought the adapter. I also have a ICOM and liked. Makes a nice
scanner also. Mine did not have the nav function.
Regards, Ross
C-172F 180HP
Sold
KSWI
Blue Angels back in Pensacola - practice session - Diamond heading back to the hangar Pensacola Beachcomber Aviation Photos 0 March 23rd 08 04:28 PM
Did VHF transceiver need TSO certificate? [email protected] Home Built 13 March 31st 07 06:27 PM
FS: Val Com 760 TSO Transceiver aieo Aviation Marketplace 8 January 25th 07 04:38 PM
FA: 760ch transceiver EOC Aviation Marketplace 0 July 27th 05 08:23 PM
Transceiver BoDEAN Products 0 April 7th 04 06:08 AM
