new twin concept from Cirrus
Old May 10th 06, 05:29 PM posted to rec.aviation.piloting
Default new twin concept from Cirrus
Thomas Borchert wrote:
It was my (mis?)understanding that a diesel is, HP/lb, heavier than a
standard aircraft engine, especially when getting into the higher
(over 250) HP models. Correct?
Not necessarily, but the big Thielert at 350 HP is heavier than an
IO-520/550. 60 pounds or so.
On the other hand, the diesel airplane will typically require less fuel in
order to complete the same mission as the avgas airplane. The saved fuel
weight can offset some or all of the weight penalty of the heavier engine.
Of course this does not apply when topping off the tanks - but in that
case, the diesel airplane gains a lot in range.
So it looks like there is a free lunch after all - at least when not
counting the acquisition costs! :-)
Greetings,
Markus
Old May 10th 06, 06:35 PM posted to rec.aviation.piloting
("Thomas Borchert" wrote)
I may have reported this here already, but I live in Hamburg, Germany,
home of the Thielert group. And at the Hamburg airport, I have seen what
seemed to be a prototype of an SR-22 fitted with the big 350-HP Thielert.
Clipboard and a white lab coat are all you'll need. Go poke around and
report back.
Thanks. :-)
Montblack
In this country we call it pulling a "Rockford".
http://www.timstvshowcase.com/rockford.html
Old May 11th 06, 11:00 AM posted to rec.aviation.piloting
Markus,
Yes, but fuel is not usually stored at the very front end of the plane (think
CG).
Thomas Borchert (EDDH)
Montblack,
report back.
I was more vague than I could have been because I have been asked to...
Old May 11th 06, 05:32 PM posted to rec.aviation.piloting
http://www.snowcrest.net/donnelly/piglatin.html
"isthay ouldshay orkway" :-)
Ontblackmay
Old May 11th 06, 07:49 PM posted to rec.aviation.piloting
Matt B. wrote:
There's a significant difference between tubronormalizing and
turbosupercharging and evidently that's what Cirrus is going after.
I don't think the turbo mod was from Cirrus, it was aftermarket. Other
than limiting boost to produce a maximum manifold pressure of X
(turbonormalized engine), what other significant differences are there
between the two systems?
Cirrus demo Dan Luke Piloting 12 December 4th 05 06:26 AM
New G-1000 182 & Cirrus SR-22 GTS Dan Luke Piloting 24 June 27th 05 08:18 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Cirrus SR22 Purchase advice needed. C J Campbell Piloting 122 May 11th 04 12:30 AM
New Cessna panel C J Campbell Owning 48 October 24th 03 05:43 PM
