new twin concept from Cirrus
Old May 9th 06, 04:26 PM posted to rec.aviation.piloting
Default new twin concept from Cirrus
I'd read several references about Cirrus developing the P-Jet, which I
assume would seat four including pilot. This got me thinking about
other segments they might explore. Considering the success of their
SR20 & SR22 series, what are the chances of a SR-derived twin? A
four-place fixed-gear composite twin (or, potentially a stretched
6-place variant) available with either the IO-360 or IO-550 if you
really wanna boogie.
My guess is such a plane with the 310hp motors should have a 210-220kt
cruise based on the Baron's advertised 200kt cruise with 300hp Contis.
The 200hp engines would make for a 180-190kt cruiser, based on the
Seminole's advertised 168kt cruise with 180hp Lycomings. The CAPS
system might be an even bigger selling point in a twin considering the
Vmc rollover potential, although that situation normally happens right
after takeoff and the acft may not have gained enough altitude for the
system to be effective. Let the pocket-protector types figger out how
to make it work at low alts. They'd also have to ditch the single lever
power controls (which I've read many pilots don't care for) and add
separate prop controls, or some kind of electric feathering control.
I don't think a Cirrus twin is too much of a stretch considering how
quickly they've caught up to Cessna after only 6(?) years building
certified acft. If the Klapmiers can make a business case for a twin I
think they'd sell quite well, even considering the cost of 100LL right
now. Hmmm, maybe Thielert diesels...
rambling mode off
Old May 9th 06, 04:33 PM posted to rec.aviation.piloting
"Kingfish" wrote in message
rambling mode off
If I was in the market for a light twin I would take a long hard look at the
Diamond twin, seems like a nice aircraft and uses what, 8 GPH *total* or
close to it!
DW
Old May 9th 06, 04:56 PM posted to rec.aviation.piloting
Yeah, I thought about the DA42, but the Cirrus would have a big speed
advantage, hypothetically. The Diamond site says 12.5gph at 80% power
which I think gives you around 170kts based on their range circle. I
couldn't scroll down to read the whole spec page so I don't know what
they're advertising for cruise speed of the diesel engined plane. I
didn't see anything on Diamond's page about the IO-360 engined DA42
either. That is a cool looking plane though.
Old May 9th 06, 05:43 PM posted to rec.aviation.piloting
I don't see any economic advantage to adding a twin to their product
line. Their singles already offer "twin-like" speeds without the expense
of the second engine and systems. I don't see any evidence that there is
demand for a new piston twin.
The development and certification costs alone would require that the
selling price be in the VLJ range.
Old May 9th 06, 06:50 PM posted to rec.aviation.piloting
expense
is
All good points and tough to argue. It was more of a "what if"
excercise. I'm sure if there was a good business case for a twin
Klapmier would be all over it.
The development and certification costs alone would require that the selling price be in the VLJ range.
Not so sure about that, though. Diamond's DA42 Twinstar lists for under
500k.
Old May 9th 06, 08:19 PM posted to rec.aviation.piloting
I would be putting my money on a diesel engine. That would be huge in
Europe. With the price of gas going up in the US, it would be a big hit
here also.
Mike Schumann
rambling mode off
Old May 9th 06, 08:35 PM posted to rec.aviation.piloting
500k.
I have not looked closesly, but I believe there is a large parts
commonality between the DA-40 and the DA-42.
This is similar to the Adam 500 and the Adam 700.
Anytime you can leverage existing parts into a new design, you reduce
costs.
The seat attach fittings on the current King Air's are the same as the
Twin Beech model 18's.
Old May 9th 06, 10:51 PM posted to rec.aviation.piloting
It would be great to see more light twins in the market, especially
more fuel efficient ones, but I don't think Cirrus will develop a
twin. Here is why.
In my mind, people buy twins for a few reasons:
#1. Safety (whether real or perceived)
#2. Useful load / size
#3. Coolness factor
#4. Performance improvement over single
For Cirrus to develop a twin, they would have to tap a market large
enough to offset their development costs.
Refering to the above points (wrt to market).
#1. Cirrus already is capturing a big chunk of the safety market b/c
of the chute. Personally, I would rather have two engines, but there
are a lot of pilots (and spouses) who like the chute.
#2. Useful load/cabin space. The twin will always be able to haul
more, but Cirrus could introduce a 6 seat single with a bigger engine
(310-350hp) to cover part of this requirement.
#3. Coolness factor. Two props is cool, but so is a glass plane and
cockpit. Of course, I guess two props, a glass plane, and glass panel
would be coolest then!
#4. Performance improvement. The SR22 is already pretty fast -
faster than most singles. They could add turbo (instead of another
engine) to get another 20-30 kts to compete against the light twins
speed and climb.
Because the SR22 is such a capable plane, I think that the available
increase in market to Cirrus for developing an SR-twin is quite small.
Since the Baron, Seneca, AdamA500, and DiamondTwin are in production,
and are all capable planes, it would make for tough competition.
I would love to be proven wrong, and see Cirrus or Lancair introduce
something at Oshkosh, but I think both of these companies are better
(financially) to focus on derivatives of their current product line
than introducing a new product.
Old May 10th 06, 12:12 AM posted to rec.aviation.piloting
I doubt it. Look at the market for used twins: it's a wasteland.
Small market + enormous development & certification costs = no twin from
Cirrus.
If I had to guess about the next big news drom Cirrus, I'd say it will be
something forward of the firewall.
Dan
C172RG at BFM
Old May 10th 06, 02:09 AM posted to rec.aviation.piloting
All good points. Probably the best argument against the twin is that
Cirrus' singles are so damn fast already. I read recently about a
turbonormalizer STC for the SR22 that boosts the cruise up to 200kts.
Not a cheap mod for an extra 15kt on the top end, but the climb is
probably pretty impressive past 8k feet. I think the next big thing
could be diesels, and a Thielert or SMA might be a nice addition to a
fast airframe.
Cirrus demo Dan Luke Piloting 12 December 4th 05 06:26 AM
New G-1000 182 & Cirrus SR-22 GTS Dan Luke Piloting 24 June 27th 05 08:18 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Cirrus SR22 Purchase advice needed. C J Campbell Piloting 122 May 11th 04 12:30 AM
New Cessna panel C J Campbell Owning 48 October 24th 03 05:43 PM
