ASG29 Panel (small) layout ideas for ClearNav II installation
Old December 23rd 15, 12:09 AM posted to rec.aviation.soaring
Sean Fidler
Default ASG29 Panel (small) layout ideas for ClearNav II installation
If anyone has any recent CAD or sketches of CNII instrument layouts in an ASG29 with the smaller panel size, I would be appreciative. Examples of completed installs are very welcomed as well.
If I do this, I have not decided if I would do both varios (nav diplay or needle) or just one.
I understand that this panel is a VERY tight fit for the ClearNav display in panel and will require all 57mm instruments to work.
Any insight, experinece or ideas are welcomed.
I may have a metric airspeed (ASG29, winter, 57mm), metric vario (winter, 80mm with 29 speed ring) and a FLARMVIEW for sale shortly. Let me know if you are interested.
Thanks in advance,
Sean
Old December 23rd 15, 01:34 AM posted to rec.aviation.soaring
I have the "original" rectangular Butterfly display. For those who have used both the Butterfly and the FlarmView display, what benefit might there be to changing displays? One thing that the Butterfly does that the FlarmView appears to not do is allow one to set or clear Stealth mode from the display controls. May be handy to have that ability based on other threads on the Stealth topic lately.
Robert
Thanks in advance,
Sean
Old December 23rd 15, 05:44 AM posted to rec.aviation.soaring
Sean Fidler
Thanks to all for the numerous emails and photos and info!
Still not sure about ClearNav or LX or keeping my SN10.
Sean
Old December 23rd 15, 02:21 PM posted to rec.aviation.soaring
Muttley
Sean
Hi Sean
check this out
http://www.alexander-schleicher.de/e...nbrett-layout/
Bruno
Old December 23rd 15, 02:24 PM posted to rec.aviation.soaring
I have the small panel with a LX9000, would my layout be any help for you? It was also very tight and only possible by modifying the Winter instruments anbit.
Old December 23rd 15, 02:58 PM posted to rec.aviation.soaring
ND
Thanks in advance,
Sean
Hey sean,
I'll send you a photo, a big airspeed and altimeter can be used, but you have to get creative. mine is a 20 naturally, and i can recall how much smaller a 29 panel is, but this general concept in the photo i'll send is worth a look. i never had a problem with the location of the altimeter, especially since the alt. is visible on the clearnav.
Old December 23rd 15, 03:46 PM posted to rec.aviation.soaring
You could put the clearnav on a pedestal, see photo showing this on Wings & Wheels (sold, page 7.......Discus 2B). Gets it closer, easier to read and saves buying small ASI, alt, vario, etc.
An option to consider,
JJ
Old December 23rd 15, 07:28 PM posted to rec.aviation.soaring
Sean Fidler
Thanks Bruno! Cool!
Old December 23rd 15, 07:29 PM posted to rec.aviation.soaring
Sean Fidler
Thanks . Yes. That would be great to look at.
Sean Fidler
JJ,
That is really cool. Thanks!
Cad drawing for ASW27 or ASG29 instrument panel Larry Goddard Soaring 16 December 30th 18 08:19 PM
How to determine if your ASG29 has the large or small panel? Sean Fidler Soaring 37 November 19th 14 07:50 PM
panel fastening ideas [email protected] Home Built 6 May 20th 08 08:21 PM
Is there a "correct" panel layout? Dico Owning 8 May 25th 06 02:47 AM
Shop Layout Questions GreenPilot Home Built 37 July 6th 04 03:47 PM
