How to determine if your ASG29 has the large or small panel?
Old November 17th 14, 09:45 PM posted to rec.aviation.soaring
Sean Fidler
Default How to determine if your ASG29 has the large or small panel?
I just learned that there are (apparently) two panel sizes available in a 29? Large and normal (or small).
1) How does one determine which one is in a given glider (without being able to easily compare it to another)? Are there dimensions or is there a simple test?
2) Can you change between the two panel sizes easily? If you have a small can you change to the large and vice-versa?
Thanks in advance...
Old November 17th 14, 09:54 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Look at this drawing (below) and compare to what you have. The small panel has taller leg cutouts - I believe these are not widely deployed so it it most likely you have the bigger panel.
http://www.alexander-schleicher.de/s...20ib%20001.pdf
You'd need to replace the entire panel pedestal that the canopy attached to.. I'm not sure if this leads to having to refit the canopy - seems like a possibility. I've not heard of it being done, but anything is possible with enough shop hours and composite material.
9B
Old November 17th 14, 10:47 PM posted to rec.aviation.soaring
Sean Fidler
Thanks. I think I have the big one, phew!
Old November 17th 14, 11:32 PM posted to rec.aviation.soaring
Sean Fidler
On second thought, it appears that I have the smaller one :-(.
https://www.icloud.com/photostream/#A25yeZFhZI0sn
Old November 18th 14, 01:03 AM posted to rec.aviation.soaring
You do have the small one.
Panel change requires changing the lower enclosure also, best done by procuring the entire assembly including the pivot arm assembly. It does not affect the canopy with the exception that it takes a good bit of time to install the pivot arm assembly so that the canopy fits correctly.
Been there- done that.
UH
Old November 18th 14, 01:17 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
UH
Just be aware that with the new panel if you scare the crap out of yourself you will no longer be able to assume a fetal position.
Old November 18th 14, 01:28 AM posted to rec.aviation.soaring
Andrzej Kobus
It looks like you have room to grow
Old November 18th 14, 01:54 AM posted to rec.aviation.soaring
Sean Fidler
Thanks all. To be honest, I do like being able to get at my feet if necessary. I think I'm staying with the current panel (fixed up) SN10/Oudie and adding the 57mm Flarm View. Anybody want to buy the FlarmView (see picture) for $200? That's $80 off new. Free shipping! I just bought this in June 2014. PM me. http://www.cumulus-soaring.com/lxnav...XNAV-FlarmView
Old November 18th 14, 04:12 AM posted to rec.aviation.soaring
Richard[_9_]
FlarmView 57 is available at Craggy Aero for quite a bit less.
Richard
www.craggyaero.com
Old November 18th 14, 05:16 AM posted to rec.aviation.soaring
Sean Fidler
I noticed that today Richard ;-). Thanks.
The FlarmView is a great unit BTW. I just happen to have a spare 57mm slot.
Cad drawing for ASW27 or ASG29 instrument panel Larry Goddard Soaring 16 December 30th 18 08:19 PM
ASG29 For Sale YourNameHere Soaring 0 May 29th 14 02:04 PM
How to simply determine the L/D of your glider jan Soaring 41 January 17th 11 02:05 AM
How do you determine remaining life of Ceconite covering? [email protected] Aviation Marketplace 2 October 8th 05 02:19 AM
Invest small Earn Large ($20 000+) promethean General Aviation 0 October 3rd 03 07:08 AM
