That is exactly what my ammeter was doing. Then one day, while the
engine was running, I reached to turn the master off. I noticed when I touched it and rotated slightle side to side that I could make the ammeter rock solid or dance, as you say. I had already cleaned every point of contact that I could get to in the electrical circuit. Bob Chilcoat wrote: On a possibly related subject, the load meter on our '74 Archer develops St. Vitus dance about 25% of the time. Battery seems to charge fine, and you can't hear any noise in the headphones, but the meter just jumps up and down a couple of time a second. No one can figure out what the problem is. The shop boys say that they see it a lot in Cherokees, and that they have seen replacing the master switch cure it. Any other ideas? -- Bob (Chief Pilot, White Knuckle Airways) "Ross Richardson" wrote in message ... On my '65 Skyhawk, I was having lots of problems with regulator/alt. The Cessna designed switch is terrible. Contact resistance is too high and if you look at the switch inside you can see wear and contamination. A good military DPST toggle would be a good choice. Larryskydives wrote: Michael, I had a problem on a 56 172 where the regulator went out after three months. We found that on the master, there were a set of contacts for the field circuit that were bad. Replaced the master switch and no more problems. May or my not apply to you plane. -- Regards, Ross C-172F 180HP -- Regards, Ross C-172F 180HP |
| Thread Tools | |
| Display Modes | |
| FA: 12V to 24V DC voltage converter | Karl Geng, N1DL | Home Built | 2 | April 21st 05 09:48 PM |
| Remote Switch for Pointer ELT --- Why Does It Need Voltage? | jls | Home Built | 1 | November 22nd 04 10:13 PM |
| Battery storage? | Roger Long | Owning | 10 | January 14th 04 03:35 PM |
| Skylane Alternator problems | MLenoch | Owning | 7 | December 11th 03 10:37 PM |
| Anyone have experience with InterAv alternator | flyer | Home Built | 6 | October 19th 03 04:24 AM |
