"John Clonts" wrote in message om... The IO-520 in my Cessna 210 is running rough. It seems to run smooth at 1000 rpm but the roughness appears above about 1400. One cylinder is “cold” and apparently not producing any power. I pulled the rocker cover and found that the intake valve spring was broken. My mechanic and I replaced it yesterday. But the cylinder is still not producing. The compression is good (74/80). The spark plugs are good. He’s going to check the flow through the fuel injector later today. Any more ideas? What should we do next? Thanks for the replies. It WAS the fuel injector, which was blocked. Cheers, John Clonts Temple, Texas N7NZ |
| Thread Tools | |
| Display Modes | |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 04:03 PM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
| rough engine just after power reduction | Sydney Hoeltzli | Owning | 11 | July 30th 03 04:37 PM |
| First Emergency (Long Post) | [email protected] | Owning | 14 | July 23rd 03 03:46 AM |
