O-320 way rich after Major + 160HP conversion + Powerflow
Old April 1st 04, 06:28 AM
Dave Gribble
Default O-320 way rich after Major + 160HP conversion + Powerflow
The O-320 in our C-172 was professionally recently professionally overhauled
(at 2300 hours and 32 years). This included an STC to 160 HP, new
millennium cylinders, new crank (a story, there..), new cam, new carb, a
repitched prop, and a powerflow exhaust.
We're past break-in now, and the plane flies great, climbs awesome. The
recurring problem is that the carb is set way too rich. After a few visits
to the A&P (each time involving a lot of carb twiddling), it is getting
better each time. It is rich enough that I find that carb heat in the
pattern induced pretty good roughness and often backfiring. In fact, I find
that I need to keep it leaned even on the ground or in the pattern (our
field is only 200' elevation). On the ground, the idle is at 650 with the
mixture in, put pull it out about an inch or 2 and it gets a lot smoother
and a little bit faster.
The mechanic feels that it will take us a few iterations to get it set up
right, since there is so much new stuff here. He feels that the exhaust may
be a big part of this.
One other clue, the EGT now reads a lot lower than it used too. They are
apparently going to re-calibrate the thermocouple so it will at least
register on the gage.
Anyone have any experience like this?
Thanks,
dave
Old April 1st 04, 04:08 PM
Dave Butler
You're right, that's not good.
In fact, I find
Leaning on the ground is just normal good operating practice.
That sounds like normal operation. Full-rich should be richer than an optimum
mixture. If full-rich gave you an ideal mixture, you wouldn't be able to
enrichen past that to give you the extra cooling you need during climb operation.
Remove SHIRT to reply directly.
Dave
Old April 1st 04, 04:46 PM
John P
-----That sounds like normal operation. Full-rich should be richer than an
optimum
-----mixture. If full-rich gave you an ideal mixture, you wouldn't be able
to
-----enrichen past that to give you the extra cooling you need during climb
operation.
Correct me if I'm wrong, but I think the "idle mixture" does not have
anything to do with high power settings.
All the "ports" open up with full throttle and gives it more fuel than
needed to keep it cool.
John Prince
"Dave Butler" wrote in message
overhauled
visits
In fact, I find
smoother
optimum
operation.
up
may
are
Dave
Old April 1st 04, 06:22 PM
Dave Butler
optimum
to
operation.
John Prince
Don't know, but that sounds plausible. Thanks for the correction. The same
mixture knob controls the mixture at both idle and full power, though.
Dave
Old April 1st 04, 07:21 PM
Ron Rosenfeld
On Wed, 31 Mar 2004 23:28:37 -0500, "Dave Gribble"
No experience with the O320, but with the Lycoming O360's, the procedure to
set proper mixture should be doable on the ground.
1. Start engine and warm up until CHT's and oil temps are normal.
2. Mag check -- if normal, proceed.
3. Set throttle set screw so idle is per airframe mfg recommendation.
4. Slowly move mixture control towards idle cut-off and observe rpm. An
increase of more than 50 RPM indicates the mixture is too rich. (An
immediate decrease, if not preceded by a momentary increase, indicates the
mixture is too lean).
5. When performing step 4, don't let the engine cut out.
6. Adjust the mixture control in the proper direction; run up to 2000 RPM
to "clear" the engine, and repeat the above as necessary. If the mixture
change has changed the idling RPM, that should be re-adjusted as needed.
7. If the setting does not remain stable, check the idle linkage for
looseness.
Old April 1st 04, 08:44 PM
jsmith
Deakin's had an AvWeb column sometime in the last three months on
setting the proper ground mixture.
Thanks,
dave
Old April 1st 04, 11:25 PM
Dave Butler wrote:
: Don't know, but that sounds plausible. Thanks for the correction. The same
: mixture knob controls the mixture at both idle and full power, though.
Yes, but think of the mixture knob as an "absolute" metering adjustment, not a
"relative" adjustment. In other words, setting the mixture doesn't set the air/fuel
ratio... basically just the maximum amount of fuel that can flow. So, to lean on the
ground with the mixture you have to pretty much pull it all the way out. As Deakin
says, if you lean on the ground, doing anything shy of almost cutting it off does no
good, and possibly harm if you forget to enrichen rull before takeoff.
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Old April 2nd 04, 01:27 AM
G.R. Patterson III
I installed tuned headers on a van once. It ran rich after that, due to the reduced
back pressure. I had to rejet the carb to fix it. That leads me to suspect your new
exhaust, but you've put a new carb on there too. Can you put the old one back on for
a flight?
George Patterson
Treason is ne'er successful, Sir; what then be the reason? Why, if treason
be successful, Sir, then none dare call it treason.
Old April 2nd 04, 01:42 AM
Dave Gribble
This is the exact procedure we've used to set the mixture. The idle is 650
rpm and the increase when you move to cut-off is only about 25 rpm.
The problem is that it still seems too rich, especially in the pattern with
carb heat on.
"Ron Rosenfeld" wrote in message
to
looseness.
Japanese firm sold Libya uranium conversion plant Dav1936531 Military Aviation 2 March 17th 04 04:47 PM
Help Me Get Rich Please 7865 Andy McKenzie Home Built 9 March 15th 04 12:53 AM
Please Help Me Get Rich 8685 Ray Andraka Owning 2 March 12th 04 02:16 PM
Auto conversion cost post Richard Riley Home Built 13 December 28th 03 01:52 PM
Thanks for the Spins Rich David B. Cole Aerobatics 17 October 26th 03 09:37 AM
