Autogas STC Paperwork
Old April 7th 04, 12:59 PM
Dan Thompson
Personally, I'd say the placard is all you need, but only if you are sure
the STC for a plane like yours is just a paper whipping excercise. If so,
I'm sure you don't even need the placard to fly on autofuel.
These autofuel STCs that are nothing more than an Adel clamp and a placard
have an "Alice in Wonderland" feel to me.
"Al Gilson" wrote in message
Our 1964 Skyhawk has a placard by the fuel cap indicating that it is
approved for unleaded auto fuel. However, I don't have any paperwork
showing that it has an STC for autofuel. Any ideas on how I could
research this information? Or...is the placard all I need?
Thanks.
Al Gilson
Spokane, WA USA
1970 VW Convertible
1964 Cessna Skyhawk
Old April 7th 04, 03:01 PM
Newps
For a 172 it's only paper whipping. However to be legal you need the
337 filled out and sent in, the logbook entry, the clamp, and the
placards at the fuel fillers.
Old April 7th 04, 09:29 PM
Bob Martin
Where does the clamp go, and what does it do? Just curious
Old April 8th 04, 04:16 PM
Bob Martin
Jim Weir wrote in message . ..
It goes on the pushrod tube. Its main function is to add 0.05 to the weight of
the aircraft without having any other use other than to prove that you spent a
dollar a horsepower to buy it..
Pushrod tube? As in the throttle linkage or something? I have no
idea what a "normal" carb looks like; we have one of those Ellison
TBI's. Sorry to be kind of dense here, but some of the things the FAA
restricts (as far as equipment and certification) seem absolutely
ridiculous.
Old April 8th 04, 04:26 PM
G.R. Patterson III
Nothing to do with the carb. Each cylinder has two valves (intake and exhaust). These
are opened by a camshaft, which is located in the center of the engine. The camshaft
lobes push indirectly on rods that run up to the top of the cylinder to activate the
valves. Each rod is encased in a tube about 3/4" in
diameter. On Lycomings, these pushrod tubes are located above the cylinders.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
Old April 9th 04, 01:10 AM
John Galban
On my old 172 (O-300) the clamp went on the giant oil filler tube.
Worked great until the oil filler tube fell off in flight :-(
Old April 7th 04, 05:52 PM
Jim Weir
If Alice can save me up to $50 each time I fill up, I say more power to her.
And, for the original post, get the 337 file from Ok City FAA for your aircraft.
You may uncover some OTHER additional "stuff" you didn't know about your
airplane. If you go to Oshkosh, the Feds *generally* have a table set up and
little gift certificates where you get the file on microfiche or CDROM for free.
"Dan Thompson"
-These autofuel STCs that are nothing more than an Adel clamp and a placard
-have an "Alice in Wonderland" feel to me.
http://www.rst-engr.com
Old April 8th 04, 05:23 AM
G.R. Patterson III
Even if the STC for your aircraft is just a "paper-whipping" exercise, beware that
the STC on many of these aircraft specifies a minimum operational rpm level. It may
be OK to dump mogas in a Cessna 150 (to pick an example) without actually springing
for the SCT, and it may not. Unfortunately, I no longer remember the rpm level for
that plane, but my A&P had to adjust the carb a tad when I bought the STC.
George Patterson
Old April 9th 04, 01:13 AM
John Galban
"G.R. Patterson III" wrote in message ...
I had the Petersen STC which also required a check for the presence
of composite floats in the carb. The previous owner skipped that
check and the floats sunk after a few months of autogas use. Ended up
with a giant puddle of fuel around the airplane.
Autogas and high end engines John Skorczewski Home Built 10 August 17th 04 06:19 PM
mixing 80 and 100 and autogas...? R. Wubben Owning 5 March 15th 04 04:28 AM
Stupid question about autogas Paul Folbrecht Owning 34 March 1st 04 03:05 AM
autogas to 100ll Ron Natalie Owning 4 January 27th 04 05:49 AM
Hot weather and autogas? Rich S. Home Built 33 July 31st 03 12:25 AM
