It is possible that misalignment between the starter and flywheel is
torquing the Bendix shaft (which caused the problem with your old starter). Otherwise, you may have gotten a defective rebuilt starter. Happens all the time, and should be covered under warranty. The Bendix should engage the starter even when there is insufficient voltage to crank the engine. The battery and/or cables are not likely to be the source of your problem -- -Elliott Drucker |
| Thread Tools | |
| Display Modes | |
| Starter Questions | Aaron Coolidge | Owning | 4 | June 30th 04 03:52 PM |
| Stuck starter solenoid? | Paul Lee | Home Built | 4 | April 16th 04 03:58 PM |
| LIghtweight starter recommendations for PA24-250? | Chris Kennedy | Owning | 4 | April 8th 04 01:01 AM |
| Starter selection -- seeking input | [email protected] | Owning | 3 | April 5th 04 01:43 AM |
| Sticking Starter | Wayne | Owning | 5 | September 2nd 03 08:26 PM |
