Violating Airspace with GPS
Old November 4th 03, 06:04 PM
C J Campbell
"Larry Dighera" wrote in message
| On Tue, 04 Nov 2003 16:00:48 +0100, Thomas Borchert
| wrote in Message-Id:
| Larry,
| Aside from ground speed, and three dimensional position (and time of
| day), what other information does GPS provide?
| Wind speed and direction, for example.
| I wasn't aware of that. What GPS has the capability to display wind
| speed and direction?
Most of them. In fact, I have not seen an aviation GPS which does not have
this capability. However, the feature is invariably so buried in a bunch of
sub-menus that it is almost useless.
  #42
Old November 4th 03, 06:13 PM
Larry Dighera
On Tue, 04 Nov 2003 17:44:59 +0100, Thomas Borchert
Larry,
Ok, you had your fun jerking my chain, so let's let it go.
Sure.
If you fail to see the usefulness of a moving map display, I can't help you.
That's your inference.
I find the moving-map GPS useful to navigate the KLAX Shoreline
Transition Route. Because ATC demands that you fly directly over the
Pacific shoreline, and it is difficult/impossible to see directly
beneath the aircraft, the GPS display helps. But I wouldn't be
without current paper charts.
Just don't use one!
I was just trying to understand your rationale. I guess you're
unwilling to share anything other than your opinion. Oh well...
  #43
Old November 4th 03, 06:14 PM
Newps
All of them. Most if not all the panel mounts will display constant
real time wind direction and speed if you wire in the inputs it needs.
Heading, altitude, etc. Some handhelds can do this but usually you
would just go to the menu and do a one time check of the winds, density
altitude and TAS.
  #44
Old November 4th 03, 06:26 PM
Larry Dighera
On Tue, 4 Nov 2003 09:04:37 -0800, "C J Campbell"
| Larry,
Without a heading information input to the GPS (most handhelds), it
would not seem possible for the GPS to calculate wind speed and
direction. Magic??
  #45
Old November 4th 03, 08:13 PM
Peter Duniho
direction. Magic??
Human data entry. Those buttons on the GPS aren't just decoration. They
allow the pilot to pass along useful information to the GPS unit. Like
heading and indicated or true airspeed (I don't know if the aviation GPSs
will do the TAS conversion for you, but there's no reason they
couldn't...you'd just have to enter pressure altitude and temperature as
well).
Pete
  #46
Old November 4th 03, 08:19 PM
Paul Sengupta
You type in the info I guess. Heading and airspeed.
Paul
direction. Magic??
  #47
Old November 5th 03, 04:29 AM
C J Campbell
have
of
| direction. Magic??
Not hardly. Even the panel mounts require manual input. Most of them will
calculate things like pressure altitude and TAS, but you have to dial in all
the info. As I said, it is a pain.
  #48
Old November 5th 03, 05:10 AM
Larry Dighera
On Tue, 4 Nov 2003 19:29:00 -0800, "C J Campbell"
Lot's of head-down time I'd expect. That's not prudent in the LA
basin. But it might be more convenient than an E6B on a long leg out
of town.
  #49
Old November 5th 03, 05:58 AM
Peter Duniho
basin.
What do you need winds aloft information for flying in the LA basin?
of town.
Yes, it would be.
Pete
  #50
Old November 5th 03, 06:41 AM
karl gruber
*******Not hardly. Even the panel mounts require manual input. Most of them
will
the info. As I said, it is a pain.*****
All you need to display a wind arrow is an HSI and an Air Data Computer. All
sorts of airplanes have Honeywell KCS-55A compass systems. Shadin has a low
cost ADC.
Combine heading and TAS and strap them into your Garmin 430/530 and it will
display the wind arrow. At least one truly useful time for that information
is on landing. The arrow will show real time wind shear.
Just bring your checkbook. The new Garmin 1000 system in the new Cessna
182/206 will have all that stuff standard. I do know that Garmin is dragging
their heels, kicking and screaming, in upgrading the 430. They should have
never promised an upgrade for that now antiquated system. An upgrade to the
1000 couldn't cost much more. All the engineering talent is going into the
1000 program. The CNX-80 is a BIG white elephant.
Garmin should offer a 1000 trade up program to the 430/530/80 owners that
they couldn't refuse. It would save a lot of headache. It's already going to
cost a mint to get TAWS, traffic, weather, and VNAV approaches on the older
units anyway.
Karl
"Curator" N185KG
Must the PLANE be IFR-equipped to fly over17,500? john smith Home Built 11 August 27th 04 03:29 AM
most of eastern Massachussetts airspace closed in July Christopher C. Stacy Instrument Flight Rules 29 June 19th 04 01:47 AM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 07:12 PM
Help - I busted into the Class B SEATAC airspace last night, does anyone have any advice ? steve mew Piloting 38 October 28th 03 07:08 PM
FA: Congested Airspace: A Pilot's Guide The Ink Company Aviation Marketplace 0 August 10th 03 06:51 PM
