"C J Campbell" wrote: Most of the problems that I have had on Cessna 172s have been with flaps. I agree that pilots should verify flaps up on touch and goes. Cessna used to have manual flaps. Why did they ever go to this flakey electrical system in the first place? "Roy Smith" wrote in message ... I did my initial training in Cessnas, and "verify flaps retracting" was drummed into me as part of the touch-and-go procedure. Now I fly mostly Pipers. I really like the manual flaps instead of Cessna's electric ones, and curse the electric trim Piper uses instead of Cessna's manual trim system. Simple stuff just works better. How exactly do Piper manual flap systems work then? We have a Piper Twin Comanche with an electric flap system. The flaps are pushed down, but come back up using springs, in effect after latches are removed. We've now had two asymmetric flap retractions, where one of the springs failed to do its job. This is Not Good. So when you lower the flap handle in a manual Piper system, does it drag the flaps up or does it merely take the latch away and allow the spring to do its job, as in the electrical equivalent? Julian Scarfe |
| Thread Tools | |
| Display Modes | |
| Flap Hinge Moment Calc | Bo | Home Built | 2 | February 2nd 05 11:26 AM |
| Flap Hinge Moment Calc | Bo | Home Built | 0 | February 2nd 05 07:01 AM |
| Flap angles | DeltaDeltaDelta | Piloting | 34 | May 18th 04 01:09 AM |
| McFarlane flap rollers - PIREP please | Roger Long | Owning | 3 | November 3rd 03 11:04 PM |
| Flap design question | Chris W | Home Built | 1 | August 4th 03 03:50 PM |
