basic spar construction
Old December 9th 04, 06:25 PM
Dave Schneider
Thank you for taking the time to answer my kind of off topic (non-airplane)
questions! I'm looking into the Quickie wing construction right now.
Dave Schneider on Dec 8, 2:05 pm wrote:
Is there any way to calculate wing loads on something like the
following
(this is where I'm going).
Of course.
The first step is to model or at least establish an upper bound to the
forces acting on it. That may be more complicated for an iceboat
than for an airplane.
Do you think the skypup construction could
handle these loads:
http://groups.msn.com/LandsailerandI...ndconstruction
Possibly. The iceboat wing may see more substantial torsional
loads than the SkyPup Wing. In general box beams are, in regard
to strength to weight ratio, very efficient for handling torsional
loads.
The SkyPup spars are more like an I-beam than a box beam.
The SkyPup, being an ultralight was designed to minimize torsional
loading on the wings to permit the use of a single spar and keep
them light as well as keeping the construction simple.
Some aircraft use two spars per wing with x-bracing between them
to handle torsional loads. Some use box beam spars. Monocoque
construction which relies on distributing the stress on the skin rather
than carrying it all on internal structure essentially turns an entire
wing into a box beam.
FF
cvjetkovic ca-65 skyfly- plywood spar? patrick mitchel Home Built 3 October 16th 04 06:26 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 3rd 04 12:41 AM
Marske spar workshop Marske Flying Wings Home Built 0 October 14th 03 05:53 PM
Carbon Spar design and construction workshop Marske Flying Wings Home Built 0 September 18th 03 06:47 PM
Worthy EAA Construction Books Brock Home Built 5 September 16th 03 08:48 PM
