basic spar construction
Old December 16th 04, 05:40 PM
Dave Schneider
I just clicked on it and it works for me. Doesn the ")" end up in the
address for you? If so, try removing it.
http://www.continuo.com/marske/carbon/carbon.htm
"B2431" wrote in message
Date: 12/14/2004 13:06 Central Standard Time
Message-id:
Thanks. I see you are using the carbon rods too. (in reference to a
previous link:
http://www.continuo.com/marske/carbon/carbon.htm)
That link didn't work for me.
Dan, U.S. Air Force, retired
Old December 17th 04, 05:30 PM
Dave Schneider
Well I bit the bullet and ordered the $95 program. That may seem like a
lot, but Don also wants to verfiy that your using the program correctly.
I'm thinking that the consulting support that goes with the program makes it
a bargan!
"Dave Schneider" wrote in message
Thanks. The prop optimizer is interesting too. My other interest is
hovercraft. Again, not an airplane, but it does have airplane components
... and I guess it does fly ... even if it is only inches above the
surface.
http://groups.msn.com/UH13p
I have emailed them and asked for the appropriateness of their programs
for
my non-standard applications.
"Fitzair4" wrote in message
Bates Engineering has a DOS computer program for designing a wing spar.
www.aeroOptimizer.com
I have met him and listen to his forums at Oshkosh many times.
Larry Fitzgerald
Old December 19th 04, 03:44 AM
I have never seen a Quickie that had a removeable canard or main wing.
( I built the single place, so I'm certain of that.) I have looked at
hundreds of pictures of other Quickies or seen them in person and have
never seen removeable wings. ( Not to say that someone out there hasn't
done it of course, but it's not in the construction plans ) The
fuselage, however, can disconnect aft of the main wing if you would
like to build it that way. It's approved, but take it from me, it's a
nightmare !! I do believe the main wing of the Dragonfly is
removeable, but I'm not sure of the canard.
Neal Fulco
James R. Freeman wrote:
Dave for Your info. The Quickie and Q2 use a fiberglass build up spar
as You
will see from the plans. The Q-200 uses a carbon fiber spar.
Yes the Quickie canard (front wing) can be removed.
"James R. Freeman" wrote in message
Dave:
I found the URL. It is:
http://www.finleyweb.net/default.asp?id=141
after a bit of surfing i found this. Is something like this
what you
are
talking about?
http://www.hinkleymall.com/airplane_cd.html
There is also this on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...ory=26441&item
=4510814564&rd=1
Basic question for the Quickie, do the wings disassemble? I'm
also
looking
for techniques for attaching wings.
Thanks!
Dave
Dave:
Take a look at the ruttan wings on a q-1 or q2 it will fit
bill
for
what you want. There is one site on the web for free downloads
of the
q2
info but I do not have the URL at hand. Q1 plan can be had on
C.D. for
less
than $10 via EBay.
Can anyone suggest some home built construction sites where
they
show
process of building a spar for a foam composite wing. I'm
confused
on
how
a
spar is built for a foam wing. It doesn't seem like the
foam
itself
would
provide enough structure to provide a web. It would seem
like
you'd
have
to cut the wing foil, cut out the location of the spar, build
spar,
and
then reinstert that section back into the foam wing.
Thanks,
Dave
Old December 27th 04, 04:34 PM
Dave Schneider
I've been looking at the plans and didn't see anything removable either.
I'm familiar with the way model airplanes join segmented wings, but I'm
unsure if they do something similar on "real" airplanes.
Neal Fulco
as You
Dave:
what you
are
talking about?
=4510814564&rd=1
also
looking
Thanks!
Dave
Dave:
bill
for
of the
q2
C.D. for
less
than $10 via EBay.
they
show
confused
on
how
a
foam
itself
would
like
you'd
have
spar,
and
Thanks,
Dave
Old December 27th 04, 08:59 PM
spar.
Larry Fitzgerald
About the Bates Engineering DOS programs....I have never used DOS and
didn't start "computin" until Windows became the "standard?" Are the
programs such that they can have the required info input into standard
Excel worksheets? If they can, the spar program would be a great tool
to play with in designing an I-beam spar similar to what the Vans
aircraft use.
Neal
Old December 27th 04, 09:11 PM
Dave Schneider
No. It is a really crude interface by today's standards. It is a very
sequential menu driven interface. By sequential, I mean that if you choose
the wrong base menu item, you have to answer the rest of the sequential
prompts until you get back to the main menu. It gets the job done, and
that's it. I grew up on DOS so it doesn't bother me too much, but I'd
certainly prefer a better interface!
I should also say that the license agreement allows you to use the program
for something like 5 years after which time you'll have to buy the program
again in order to continue to use it. I'm not sure if there is any time
bomb in the program that actually prevents you from using it. I suppose I
could move my clock ahead and see what happens.
spar.
Larry Fitzgerald
aircraft use.
Neal
  #28
Old December 27th 04, 11:41 PM
Anybody know of any other programs available for designing spars that
will use the more friendly Excel format?
Thanks in advance
Neal
  #29
Old December 28th 04, 09:49 PM
tffy
http://www.continuo.com/marske/perfo...lculations.htm
I would suggest you grab a college-level structures textbook and make
sure you understand all the inputs that are used...
  #30
Old December 30th 04, 03:07 PM
Dave Schneider
BTW: I already mentioned this, but Bates Engineering requests that they
verify that your spar design by sending them output from the spar optimizer.
My application isn't a life or death situation, but the intended use of this
program IS. If I was thinking about building something that actually flew,
I think I'd opt for a proven design and construction method over something
designed by my inept engineering expertise. :-)
"tffy" wrote in message
cvjetkovic ca-65 skyfly- plywood spar? patrick mitchel Home Built 3 October 16th 04 06:26 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 3rd 04 12:41 AM
Marske spar workshop Marske Flying Wings Home Built 0 October 14th 03 05:53 PM
Carbon Spar design and construction workshop Marske Flying Wings Home Built 0 September 18th 03 06:47 PM
Worthy EAA Construction Books Brock Home Built 5 September 16th 03 08:48 PM
