Weight saving exercise.
Old March 25th 05, 06:11 AM
Fortunat1
Default Weight saving exercise.
I have to begin making a few decisions on how to drop a few pounds (off my
butt and my airplane!)
For one, I'm considering making the composite tank as outlined in Tony
Bengelis' book. This would be the foam/glass sandwich he describes. Questin
is, is it lighter than the aluminum tank specified in my plans? I'm sure
part of it is how much resin you lather on, but is it possible to save a
couple of pounds here? Leaving the wieght aside, it's an attractive looking
propostion. By the way, the tank is a removable wing tank, about 4'by 2' by
5".
Next, what's the lightest practical covering? Biplane, weighs about 1450
lbs, redlines at 150 mph. In other words, what's the lightest system for a
cub type machine?
Finally, Wheels and brakes. They need to be reasonably robust and the plans
call for cessna type axles, wheels and brakes, but can imake any
significant savings by subsitituting something else? I don't want to put
plastic wheelbarow whels on , by the way! I'm talking about maybe
substituting cub, luscombe,whatever might be suitable which will give me a
few pounds.
any suggestions aobut these or any other tricks anyone might know greatly
appreciated!
Old March 25th 05, 08:16 AM
Jan Carlsson
Hi,
I don't think you save weight by using glass/foam, maybe if you use the
Kevlar/glass combo fabric.
For wings use dacron 2,4 oz and not to much paint.
use a wood or composite prop not aluminum
for the rest of the body, use meat, fat, egg, fish, vegetable, fruit.
stay out of rice, potatoes, pasta, bread (Atkinson method)
Jan Carlsson
www.jcpropellerdesign.com
"Fortunat1" skrev i meddelandet
Questin
looking
by
5".
cub type machine?
plans
few pounds.
appreciated!
Old March 25th 05, 09:03 AM
Fortunat1
"Jan Carlsson"
Hi,
the Kevlar/glass combo fabric.
He he, thanks,.
I've been poking around th eAircraft Spruce site trying to figure out how
much a bare composite tank is and it loks to be almost exactly the same as
an aluminum one. I might still do it because I don't realy want to build an
aluminum one and the composite loks easy. The prop's a done deal, though,
Fairly large Ham Standard ground adjustable! Very heavy. If I don't get the
performance out of it, I might try a wooden one though if this one doesn't
work out. The fabric and finish sound god though!
thanks
Old March 25th 05, 09:07 AM
Fortunat1
Bryan Martin
sednews:BE693745.3CE41%bryanmmartinNOSPAM@comcast. net:
You probably won't save any weight with a fiberglass tank. Homemade
fiberglass lay-ups tend to be a lot heavier than aluminum for the
equivalent strength. The big advantage of fiberglass isn't weight,
it's the ability to easily form it into complex shapes.
OK, thanks. I wasn't actually thinking of a layup, but a foam core
construction made of foam sheet coverd in two layers of glass cloth each
side amd made up into box. Looks like it should be light enough, but I
can't tell how much epoxy i'm going ot need. The tank would be about 23 Sq
feet in surface area, one side, of course, si double it and add a bit for
baffles and I need to glass and epoxy about 50 sq. feet of 1/4 inch foam.
any notion how much epoxy is needed? I've only ever done little patching
jobs with epoxy
Old March 25th 05, 08:04 PM
Jan Carlsson
You can probably make a little bigger tank in composite, I have made 2 using
wet lay-up over a foam plug, ((one with plastic cover material for
buildings) and one I put gasoline in the foam and scraped the gunk out) no
foam sandwich in the walls, and a couple bulkheads in the tank, and a large
sump with drain and outlet for the fuel line.
Used 3-4 layers of 300-400 gram fibre glass, the epoxy is about the same
amount as the glass.
Jan
"Fortunat1" skrev i meddelandet ...
Bryan Martin
jobs with epoxy
Old March 25th 05, 08:54 PM
How did you get to this point in the first place, maybe based on that
we can make some suggestion. Was the design overweight by design or
was it over built? How close is the empty weight to that of the
prototype?
Old March 25th 05, 11:32 PM
Fortunat1
Richard Riley
On 25 Mar 2005 09:07:19 GMT, Fortunat1 wrote:
:Bryan Martin
:sednews:BE693745.3CE41%bryanmmartinNOSPAM@comcas t.net:
: You probably won't save any weight with a fiberglass tank. Homemade
: fiberglass lay-ups tend to be a lot heavier than aluminum for the
: equivalent strength. The big advantage of fiberglass isn't weight,
: it's the ability to easily form it into complex shapes.
:OK, thanks. I wasn't actually thinking of a layup, but a foam core
:construction made of foam sheet coverd in two layers of glass cloth
:each side amd made up into box. Looks like it should be light enough,
:but I can't tell how much epoxy i'm going ot need. The tank would be
:about 23 Sq feet in surface area, one side, of course, si double it
:and add a bit for baffles and I need to glass and epoxy about 50 sq.
:feet of 1/4 inch foam. any notion how much epoxy is needed? I've only
:ever done little patching jobs with epoxy
Figure, as a rule of thumb, the epoxy will weight 50-60% of the glass.
But for a tank, that fraction goes up, since you want the inside
laminate very wet and no leaking dry spots.
Aluminum will be lighter.
OK, thank you very much..
Sold.
Old March 25th 05, 11:33 PM
Fortunat1
"Jan Carlsson"
using wet lay-up over a foam plug, ((one with plastic cover material
for buildings) and one I put gasoline in the foam and scraped the gunk
out) no foam sandwich in the walls, and a couple bulkheads in the
tank, and a large sump with drain and outlet for the fuel line.
same amount as the glass.
OK thanks. Nice to have a few figures to work with. I can see there's no
weight advantage, definitely.
Thanks again to all! Any other weight saving suggestions welcome, though!
Old March 25th 05, 11:58 PM
Rich S.
"Fortunat1" wrote in message
. . . so I'm going to have to learn to build an aluminum
tank..
Anyone know of a resource to show me how?
The books by Tony Bingelis have excellent tips on this.
http://www.amtbooks.com/sport_plane_...on_techniq.htm
Rich Shankland
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
Dutch Roll SelwayKid Piloting 31 June 19th 04 11:43 PM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 04:03 AM
F35 cost goes up. Pat Carpenter Military Aviation 116 April 11th 04 07:32 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
