Weight saving exercise.
Old March 29th 05, 04:34 AM
Roger
On Mon, 28 Mar 2005 01:46:36 -0500, "Morgans"
"Highflyer" wrote
It isn't all that bad, Rich. I use the same Smith torch and tanks for
aluminum as for steel. Use an aluminum flux and soft aluminum filler rod.
I would use a cheap spot welder to tack in the baffles. They work great
on
aluminum.
Isn't it true that most pros use TIG to weld aluminum? A good aluminum TIG
weld is a work of art. Can gas welding make as beautiful a fillet as TIG?
Better... But certainly not by me.
There was an article in ... I think it was Sport Aviation, or
KitPlanes about a year or so back. The TIG welds looked really good
until you looked at what they did with a torch.
I tried gas welding (or soldering) with a cheap torch with some of that
"miracle rod" quite a few years back before I was interested in building
planes, or really, even welding. The results were horrid. I'll have to
Bout echoes my experience.
www.rogerhalstead.com
give it a try with some proper rod and stock, now that I have a good torch.
What size tip, by the way? (Smith)
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
Dutch Roll SelwayKid Piloting 31 June 19th 04 11:43 PM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 04:03 AM
F35 cost goes up. Pat Carpenter Military Aviation 116 April 11th 04 07:32 PM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
