Insurance for Cirrus SR20 and SR22
Old March 30th 05, 07:21 PM
Dude
"BTIZ" wrote in message
news:g%q1e.436$ZV5.418@fed1read05...
Currently the Cirrus is having a higher accident rate per hours flown than
most other single engine aircraft... it's new.. and harder to fix for
minor dings than bent sheet metal..
Its not harder to fix, you have to have a different skill set. A minor flaw
in aluminum costs almost exactly the same to repair from my experience. The
only difference is that the metal plane likely has a harder to match color.
Also, I do not fly a Cirrus, but have seen that pilots used to C-182s or
Mooney's are not used to the speed and fast wing of the Cirrus... lots of
long hot landings on short runways...
Which Mooney are you speaking of? Any Mooney built in the last decade is
faster than a Cirrus. Of course, it also likely has speed brakes, and is
more respected by its pilot. Ask a few Cirrus pilot (or any others) which
plane requires more skill and attention, and they will undoubtedly say the
Mooney. I think that is why the Cirrus accidents reduced when they started
more training. The Mooney guys were mostly getting that kind of training
already.
Old March 30th 05, 07:22 PM
Dude
The other issue is that the Cirrus is an unknown. There just isn't enough
of them out there to get good statical data. Of course, the insurance
industry will error on the negative side for you (positive for them.)
How many planes, and flight hours, do you propose is necessary before it is
statistically relevant?
Old March 31st 05, 03:36 AM
Michael
decade is
Any Mooney built in the last decade is an R-model or later, and there
weren't many of those built. I have some time in an F model and also
in an R model, ant they're only vaguely similar.
And in any case has retractable landing gear. I have some time in a
Cirrus as well, and mostly I've noticed that it requires more thought
given to descent planning than anything else I've flown - BE-55, C-310,
PA-30, M20R, and the 33/35/36 Beeches included. The full flap speed is
low, the first notch won't do much, and the gear is fixed yet the plane
is still clean and slippery. I didn't find it to be a challenge, but
then I had close to 1000 hours in those sorts of planes when I flew it.
I doubt it's the guys with that experience level who are having the
accidents.
and is more respected by its pilot.
And there's the main issue. I have a feeling that once insurance
companies get used to treating the Cirrus they way they treat expensive
new big-engine Bonanzas and Mooneys, the accident picture will smooth
out.
say the
Mooney.
I wouldn't say that. Having flown both the modern Mooney and the
Cirrus, I think it's really a wash. The older Mooney is easier -
things happen slower, it's easier to slow down, etc. The Bonanzas are
definitely easier - to slow down/get down and to land. The Cirrus is
not a simple airplane, to be compared to a C-182. It's a fast,
slippery airplane comparable to an A36/V35 or M20R/S, and more
demanding in some respects. It's missing a couple of levers, but
that's not where the complexity comes in.
training
already.
I think you're right on the money there.
Michael
Old March 31st 05, 07:18 AM
Dude
say the
Mooney.
I am with you there, and from the rest of your comments, I think you are
more informed than most. You would likely be in the minority of our poll.
We agree totally.
Old March 31st 05, 02:16 PM
Dave
Interesting..
I have not flown one, so I have to depend on the thoughts/theories of
others.
The Aircraft appears to be correctly ptoportioned with the
possible exception of the center of laterial (side) area, (smallish
vertical fin/rudder) maybe causing this center to be well aft, like a
float plane without the sometimes required sub fins added...
But no one has reported any yaw instability or dutch roll
tendencies. (?)
Spin recovery/training is part of the training in Canada, - we
spin ours often just cause it is a hoot and keeps us aware of the
"feel" of what can cause a spin etc.
We get to practice our recovery techniques often, and feel
it's a good thing to do in trying to stay "sharp" with the aircraft..
Nice aircraft, but the whole idea if an aircraft that has (for
me) a serious design issue is troubling.
Thanks for your reply..
Dave
On Wed, 30 Mar 2005 17:15:22 GMT, "Dude" wrote:
Anybody here have any theories as to why (aerodynamically) this design
has recovery problems?
Dave
I got theories, but given my level of expertise, they are better labeled
guesses. I have to warn you that just asking that question is considered
heresy by many. Obviously, anyone outside of the government or Cirrus would
have to have a LOT of resources and motivation to figure this out for real.
Maybe one of the big insurers might care enough, but they would likely only
bullly Cirrus into doing the testing. USAIG has reportedly come to call in
Duluth, but has not yet demanded that Cirrus perform the normal tests in
spite of the BRS supported waiver.
Looking at a Cirrus it seems to me the CG may be too high above the wing.
Of course, this is even more true about many modern Bizjets, but intuitively
it would seem to be a bad thing for spin recovery.
The wing loading seems to be pretty high compared to the weight of the
plane, but I have no idea how this relates. In fact, if you look at the
Bizjets again, it would seem that this is not necessarily a problem.
Lastly, the shape of the wing is very complex, and it would seem that they
over did it on the spin resistance bit. How this makes it tough to recover,
or even if its a factor is unknown.
The bottom line may be that the growth of BRS technology that Cirrus is
indirectly funding could be worth the losses in the long run (not that the
families of the lost will see it that way). It could also be that after we
get another few million hours, the Cirrus will prove to be as safe as the
Cessna's and Diamonds (but I think the verdict is in already).
For me, it all didn't matter. I am convinced that the quality is just not
there. In spite of the G2 improvements, I think they are still a long way
behind the other major players, and especially behind Lancair and Diamond.
Old April 1st 05, 02:47 AM
Dave
WHOOPS!
Thinking one thing, typing another.......
On Thu, 31 Mar 2005 08:16:05 -0400, Dave
Should have written.."causing this center to be well _forward_"....
...Sorry.....
Dave
Interesting..
others.
tendencies. (?)
Dave
Dave
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Cirrus Deploys Chute Safely m alexander Home Built 40 September 28th 04 01:09 AM
SR20 vs SR22 exhaust Ben Jackson Owning 14 April 29th 04 05:29 PM
