PTT switch for 172N
Old January 15th 05, 07:08 PM
Henning DE
Default PTT switch for 172N
Hello Cessna owners !
I want to add PTT-Switches to the controls of a 1977 172N.
Since the control horns are not hollow i don`t know how.
Any suggestions ?
Henning Dammann-Emden
Bremen/Germany
Old January 15th 05, 10:06 PM
WallyX
There are PTT switches available that attach to the controls with velcro.
The wiring runs externally.
"Henning DE" wrote in message
Any suggestions ?
Bremen/Germany
Old January 16th 05, 03:15 PM
Stealth Pilot
On Sat, 15 Jan 2005 20:08:04 +0100, "Henning DE"
Any suggestions ?
Bremen/Germany
my friend's cessna 150A has the same problem.
I made up aluminuim clamp blocks that mount on the control tube hard
up against the front of the yolk. the side of the clamp block has a
recess that the switch is mounted in. switch sits up just proud of the
clamp block. press your finger down on the top of it to talk.
cable is a curly tail down to the panel under the control mount.
it doesnt limit the control movement.
has been in use about 4 years now without mishap.
friend and his LAME love it.
Stealth Pilot
Old January 16th 05, 11:27 PM
Al Colunio
My old flying club in NY purchased four rubber (plastic) covers with a PTT
built in. They slide over the horns of the control wheel and have a curly
wire into the instrument panel. They worked great and have been in use for
four years. I don't know where they were purchased.
"Stealth Pilot" wrote in message
Any suggestions ?
Bremen/Germany
Stealth Pilot
Old January 19th 05, 02:00 AM
I used C150 horns for my homebuilt and with long drill bits bored holes
through for both the PTT and AutoPilot.
See http://www.abri.com/sq2000/finish08.jpg and
http://www.abri.com/sq2000/instrument09.jpg
Any suggestions ?
Bremen/Germany
Old January 19th 05, 05:06 AM
roberth
I drilled some very small holes in the backside of the control yoke and
gently tapped them to accept a small screw. Attached a piece of
aluminum with a SPST NO push button switch from a local electronics
store. A curly cord attached to the yoke with a cable tie and thru the
inst panel with a strain relief. Seems to work well and my mechanic
had no problem with it. Only regret is that I didn't buy a high
quality switch and may have to change it. I didn't invent this whole
idea, I stole it from the folks on the group. You know who you are
-- Thanks
roberth
Remote Switch for Pointer ELT --- Why Does It Need Voltage? jls Home Built 1 November 22nd 04 09:13 PM
Jim Weir - PTT switch article? Corrie Home Built 2 October 4th 04 04:46 PM
Fuel dump switch in homebuilt Jay Home Built 36 December 5th 03 02:21 AM
Terra Switch repair George A. Graham Home Built 1 October 25th 03 12:15 AM
Could someone please describe circuitry of a PTT switch? Aardvark Home Built 4 September 26th 03 05:31 AM
