Question about rivets and riveting....
Old May 5th 05, 11:04 PM
gregg
Default Question about rivets and riveting....
Hi all,
I am a complete newbie to the world of riveting. I have to do some and I
know nothing about it.
It *IS* aircraft related, though not directly. I'd appreciate any help I
could get:
I am refurbishing a old P-series flight helmet. They had leather oxygen
mask tabs, with snaps, on the sides which were riveted to the helmet.
I have the rivets that one used back then but I do not know their
nomenclature nore do I know how they work nor what tool I need to set them.
I'll try to describe the, and I can snap a digital photo and email it if tht
would help:
The rivet comes in two pieces. one - the outside - has a solid head, and
the shank is hollow.
The mating part has a head that's the same diameter, but it's not solid. Yu
cna sight right down the shaft - it too is hollow.
the second part fits inside the first part.
You can see a photo of one on:
http://www.eleathersupply.com/fasteners.shtml
Scroll down tot he 7th item
Stock #127111-7513
Steel Single Cap Rapid Rivets
how are they set?
What sort of tool would I use?
Thanks
Saville
Replicas of 15th-19th century nautical navigational instruments:
http://home.comcast.net/~saville/backstaffhome.html
Restoration of my 82 year old Herreshoff S-Boat sailboat:
http://home.comcast.net/~saville/SBOATrestore.htm
Steambending FAQ with photos:
http://home.comcast.net/~saville/Steambend.htm
Old May 6th 05, 03:41 AM
jesse
--- 8th--- item down
Stock #8056-8100
Rapid Rivet Setter and anvil
Sets small, medium and large Single and Double Cap Rivets
Really?
You didnt see that?
Come on now...
Old May 6th 05, 11:59 PM
gregg
Stock #8056-8100
Really?
You didnt see that?
Come on now...
Jesse,
Yes I saw it. But I probably should have been more informative in my
original email:
I cannot use that to set the rivets because that would be on the inside of
the helmet where I can't swing a hammer.
So I'm hoping there is another tool that can be used to do the job. I've
seen "rivet squeezers" but I do not know if they work with these sorts of
rivets.
thanks for your answer
Saville
Old May 7th 05, 05:29 PM
John T
Is the only way to put the rivet in to put the punch (part that is
hammered) inside the helmet? If not, see if you can put the other tool
half (anvil?) on some kind of protuding "real" anvil that is inside the
helmet?
This isn't a snap, right? I'd think it wouldn't matter which rivet end
goes inside the helmet.
John
Old May 7th 05, 07:32 PM
gregg
helmet?
John
Hi John,
Yeah it's the only way. It would look horrid otherwise. One end has a
smooth head - the outside part.
But the part you place the punch against is shaped kind of like the business
end of a trumpet though the "bell" is flatter.
That's why I was wondering if a "rivet squeezer" would work.
Saville
Old May 8th 05, 02:34 AM
John T
Well, I guess you could try something like back riveting. In this case,
put the punch in a vise or something that can hold it steady and upright
(trumpet shaped end up), with the far end of the punch resting on
something hard and solid (chunk of steel, or the vise shaft), slip the
helmet over the punch and position it, and use the hammer to wack the
rivet anvil. Would probaby be a two person job.
John
Old May 8th 05, 05:05 AM
Smitty
gregg wrote:
Hi all,
Stock #127111-7513
how are they set?
Thanks
This isn't an aircraft rivet, it's a sewing rivet, used in clothing and
upholstery. (and flight helmets) So, you're in the wrong newsgroup for
experience in setting these things. I'd check with a local seamstress or
tailor shop, or the local arts and crafts leather belt maker, who can
probably set them for you for a couple of bucks. I remember a g/f who
used to work in upholstery telling me about these things.
But it seems to me that you could set it with an arbor press, fitted
with a concave swager so that it doesn't deform the head, and an
appropriate block on the backside.
From the ground up ... question about riveting Marco Rispoli Home Built 4 July 19th 04 02:05 AM
Shinn brake linings - bonding vice riveting Michael Horowitz Owning 0 July 12th 04 05:47 PM
Poppers Revisted and the Return of the Teenie Two Veeduber Home Built 0 March 29th 04 10:57 AM
