Removing the coatings?
Old October 8th 05, 07:42 PM
Michael Horowitz
Default Removing the coatings?
This is a hypothetical question.
If you were faced with a Ceconite covered wing, and you wanted to
remove coating back to the fabric and start with a new silver coating,
is there any way to gracefully do that?
I'm visualizing someone trying it with MEK and a lot of rags and a
big mess. - Mike
Old October 8th 05, 09:32 PM
Cy Galley
Although paint remover can be used on Ceconite, most removed paint is done
mechanically.
As I understand, first the seam tapes are ripped off. This leaves an edge
which a putty knife can then peel off all the paint. Just make sure to have
rounded corners on the knife and you will find the paint strips down to
bare fabric,The might be a few spots that you will have to use MEEK or paint
remover. This process is used quite frequently on Bellanca Vikings. Check
with Miller Aviation in Texas for the details.
Cy Galley - Bellanca Champion Club
Newsletter Editor-in-Chief & EAA TC
www.bellanca-championclub.com
Actively supporting Bellancas every day
"Michael Horowitz" wrote in message
news
big mess. - Mike
Removing cherokee wings.. pho Home Built 9 February 26th 05 07:10 PM
Removing old antennas Jay Honeck Owning 30 March 21st 04 04:34 PM
Removing a Major Alteration. JDupre5762 Owning 5 March 19th 04 06:25 PM
Removing Old Contest Numbers Milan Air Soaring 5 November 25th 03 12:59 AM
F-14 squadrons removing refueling cover plate? dave999 Military Aviation 7 August 6th 03 09:45 AM
