misdrilled hole on on tubular aluminum spar question
Old October 2nd 06, 09:03 AM posted to rec.aviation.homebuilt
patrick mitchel
Default misdrilled hole on on tubular aluminum spar question
"Rich S." wrote in message
news
"Orval Fairbairn" wrote in message
news
Am I missing something here? Is this a low wing or a high wing?
Rich "Mid Wing" S.
high wing- pat
Old October 2nd 06, 10:11 AM posted to rec.aviation.homebuilt
Canalbuilder
news
news
Rich "Mid Wing" S.
high wing- pat
In that case the strut will be in tension during flight, and compression
while the microlight is on the ground (unless it's very windy). Either
way, the best thing to do is consult the designer and do exactly what
they say.
Ed
Old October 2nd 06, 09:17 PM posted to rec.aviation.homebuilt
jerry wass
news
There's a discussion on a ul ng about a guy that built a strut braced
light
plane and in a fit of overkill (apparently ) decided to add a (non
plans)
jury strut. He drilled a hole (3/16") on the bottom of the tubular alum
spar. Then realized he may have made a mistake. Whats the outcome and
is
there a fix without putting in a new spar. Just curious (and I didn't
do
it!!) Pat
snip
The strut is in tension and at an angle to the spar which puts a compression
load on the spar. Aerodynamic forces between the strut and the root tend to
lift the wing, which increases the compression on the bottom of the spar
between the strut and root (supported at both ends).The moment applied at
the strut from the outboard portion of the wing tends to put the top in
compression, the bottom in tension. The net result (tension or compression)
depends on the details of the geometry - how far out is the strut and what
kind of angle is it at.
In any case, I would want to put a doubler over the hole...
You're SO RIGHT --I forgot to tack on the overhanging portion of the
wing---Jetty
Geoff
Question about Alodine 1201 Andrew Sarangan Home Built 20 April 11th 06 02:31 PM
Tech: Aluminum Forming Question Scott Rodriguez Home Built 5 March 15th 06 05:42 AM
mismatched hole question Dick Restoration 5 October 17th 04 01:43 PM
epoxy aircraft seats? Lpmcatee356 Home Built 26 December 4th 03 12:16 AM
DuoDiscus Wing Duane Eisenbeiss Soaring 27 October 31st 03 03:34 AM
