It's the same prop. Just put it on backwards.
Karl ATP CFI "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:vZSdnVUBModXwfLYnZ2dnUVZ_rKdnZ2d@wideopenwest .com... "Jim Macklin" wrote in message ... The cost of manufacturing two versions of the engine and recertification of the design is not worth the small advantage. Most light twins were designed and certified over 40 years ago. What would be all the unique parts? Camshaft has to be different. Crankshaft probably is drilled differently for the oil passages. Starter. Oil pump. Magnetos. Vacuum pump, I assume? Prop, obviously. That should be about it? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
| Thread Tools | |
| Display Modes | |
| Light twins not using contra-rotating propellers | Mxsmanic | Piloting | 120 | December 5th 06 01:49 AM |
| Light twins not using contra-rotating propellers | RomeoMike | Piloting | 6 | December 2nd 06 02:47 AM |
| Light twins not using contra-rotating propellers | Newps | Piloting | 0 | November 30th 06 08:40 PM |
| Light twins not using contra-rotating propellers | Greg Farris | Piloting | 0 | November 30th 06 08:25 PM |
| The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 01:07 PM |
