Light twins not using contra-rotating propellers
Old December 1st 06, 08:29 PM posted to rec.aviation.piloting
Mxsmanic
Default Light twins not using contra-rotating propellers
Stefan writes:
The most simple solution would be the possibility to trim all
three axis.
Hmm ... is trim in all three axes uncommon? The Baron has aileron,
elevator, and rudder trim.
On the more expensive level (much more expensive, I would guess), you
can overcome the P-factor effects by using two contra-rotating coaxial
propellors. This would not only overcome the effects of the P-factor,
but also those caused by torque. Kamov helicopters are an example of
such a design.
With a single powerplant turning in one direction, there would still
be some residual torque from the engine itself.
Light twins not using contra-rotating propellers RomeoMike Piloting 6 December 2nd 06 02:47 AM
Light twins not using contra-rotating propellers Newps Piloting 0 November 30th 06 08:40 PM
Light twins not using contra-rotating propellers Greg Farris Piloting 0 November 30th 06 08:25 PM
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB Mal Soaring 59 October 4th 05 06:39 AM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 01:07 PM
