#21
Well... it's like this... The story was told to me one day back around 1980,
after the operational techniques had suddenly changed--and become much more conservative. I just checked FAA's accident database for Hollywood, FL for the period from 1970 through 1990 and found no refference to any similar accident. At this point, I can only presume that someone was "yanking my chain" and I made the mistake of repeating the story without checking it out, even though such stories are now quite easy to verify. Peter Sorry about the incorrect report. "Peter Dohm" wrote in message news:1Mmih.895$_X.3@bigfe9... No, at North Perry (HWO) Peter "Frank Barchi" wrote in message . net... Was that accident at FXE? Frank "Peter Dohm" wrote in message ... wrote in message oups.com... Montblack wrote: ("Judah" wrote) On the other hand, if the Pilot stalled the aircraft (either with or without engine power) by not properly managing the airspeed across his wings (for example by climbing too aggressively), the plane may lose its lift (aka stall), and drop its nose somewhat suddenly. One year at OSH, hanging out at the Ultra-Light pasture, I heard the field announcer put a stop to pilots trying to outdo one another with over aggressive climbouts. He was pretty stern with his warning. Montblack Eight or 10 years ago at Arlington a fella killed himself that way. I watched it happen. Short takeoff and steep climb to about 200', then a fairly steep turn to return to the runway to demonstrate the short-field capability of the airplane (an advanced ultralight). He did it several times until it finally bit him. The airplane went left wing/nose down and rotated into the ground. Classic stall/spin scenario. Too many ultralight pilots get too little training and do too little reading on their own. And, like the rest of us males, they hate to be outdone and might push things farther and farther until one of them dies and the media have more junk to feed to the masses. I can understand the "stern" warning. That field announcer might have witnessed the same accident I did. Dan About 25+ years ago at one of our local airports, in southeastern Florida, the rag draggers used to make a very short takeoff at roughtly mid-field, level off at around 50 feet, and make a very steep turn to transition across the airport to their pick-up area. One had a mishap, and after that the operation was much more conservative. I never heard the details or extent of damage, but suspect that the apparent headwind may have only been a long gust. Peter |
wrote in message oups.com... Montblack wrote: ("Judah" wrote) On the other hand, if the Pilot stalled the aircraft (either with or without engine power) by not properly managing the airspeed across his wings (for example by climbing too aggressively), the plane may lose its lift (aka stall), and drop its nose somewhat suddenly. One year at OSH, hanging out at the Ultra-Light pasture, I heard the field announcer put a stop to pilots trying to outdo one another with over aggressive climbouts. He was pretty stern with his warning. Montblack Eight or 10 years ago at Arlington a fella killed himself that way. I watched it happen. Short takeoff and steep climb to about 200', then a fairly steep turn to return to the runway to demonstrate the short-field capability of the airplane (an advanced ultralight). He did it several times until it finally bit him. The airplane went left wing/nose down and rotated into the ground. Classic stall/spin scenario. The theory about that accident in the RV community is that the pilot had used the seatbelt on the passenger's side as a control lock, was in a rush to leave the show, and didn't do a control check before takeoff. With the belt latched, the elevator was in an "up" configuration, and the rest, unfortunately, is history. KB snip Dan |
Kyle Boatright wrote: What are the odds that the pilot stalled the aircraft and the engine was performing just fine? Writers often miss the fact that the word "stalled" has an additional meaning in the aviation realm. I sometimes think the aviation community should come up with an alternative description for a wing "stall", so that the layman doesn't confuse it with engines. Anyone care to propose a nice short descriptive phrase? Of course, it's going to be impossible to impose. Sort of like the attempt to change from "uncontrolled airports" to "nontowered airports" :-) Kev |
"Kev" wrote in message ps.com... Kyle Boatright wrote: What are the odds that the pilot stalled the aircraft and the engine was performing just fine? Writers often miss the fact that the word "stalled" has an additional meaning in the aviation realm. I sometimes think the aviation community should come up with an alternative description for a wing "stall", so that the layman doesn't confuse it with engines. Anyone care to propose a nice short descriptive phrase? Of course, it's going to be impossible to impose. Sort of like the attempt to change from "uncontrolled airports" to "nontowered airports" :-) Kev Actually, I believe the new buzz phrase is "Pilot Controlled Field." At least that's what was used in multiple seminars at this past AOPA Expo. Jay B |
Jay Beckman writes:
Actually, I believe the new buzz phrase is "Pilot Controlled Field." That implies that pilots are not in control at other fields, which is just as bad (if not worse) than implying that a field is out of control. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
: It is equally likely that aviators reading the article will make snap judgements about what the journalist did or did not know or understand, and will imagine their own version of the story that may be dramatically different from what was reported. Both are just stories... Accurate facts will be listed in the NTSB report. |
"Kev" wrote in
ps.com: I sometimes think the aviation community should come up with an alternative description for a wing "stall", so that the layman doesn't confuse it with engines. Anyone care to propose a nice short descriptive phrase? Why should we have to change our use of the term? I think the new term for an engine stall should be an engine shutdown, and stall should relate only to loss of lift over a wing or other airfoil. ![]() |
#28
Mxsmanic wrote: Jay Beckman writes: Actually, I believe the new buzz phrase is "Pilot Controlled Field." That implies that pilots are not in control at other fields, which is just as bad (if not worse) than implying that a field is out of control. No, it implies (to non-pilots) that Towers are in control of other fields. Remember, most laymen believe that ATC is in charge of every plane every second, and are surprised when they hear about an airplane taking off without filing a flight plan. Kev |
#29
Kev writes:
No, it implies (to non-pilots) that Towers are in control of other fields. Remember, most laymen believe that ATC is in charge of every plane every second, and are surprised when they hear about an airplane taking off without filing a flight plan. I think it's safe to say that the average layman has never heard of ATC or flight plans. They just think that pilots take off and fly to their destination. They only call ATC when a mad bomber explodes something in the starboard can, injuring a pregnant and pretty stewardess, or when the top of the plane is ripped off and they need Charleton Heston to bring them in safely. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#30
"Judah" wrote in message . .. "Kev" wrote in ps.com: I sometimes think the aviation community should come up with an alternative description for a wing "stall", so that the layman doesn't confuse it with engines. Anyone care to propose a nice short descriptive phrase? Why should we have to change our use of the term? I think the new term for an engine stall should be an engine shutdown, and stall should relate only to loss of lift over a wing or other airfoil. ![]() The problem is the word stall means something to the general public. When they hear the word stall they associate with something they understand in this cas, the engine stopping. |
| Thread Tools | |
| Display Modes | |
| Garmin 300XL GPS Approach didn't arm | Steve S | Instrument Flight Rules | 9 | May 11th 06 03:54 AM |
| Trust those Instruments.... Trust those Instruments..... | A Lieberman | Instrument Flight Rules | 1 | May 2nd 06 04:54 PM |
| Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 12:13 PM |
| Where is approach good about multiple approaches and clearances in the air? | Andrew Gideon | Instrument Flight Rules | 29 | February 14th 04 03:51 AM |
| IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 10:03 PM |
