Inner Tubes
Old May 13th 07, 02:27 AM posted to rec.aviation.owning
Rip
Default Inner Tubes
RST Engineering wrote:
I understand there is a new class of inner tubes that do not leak as
severely as the old
"TSO'd crap" natural rubber that we've used since Wilbur put them on the
Flyer.
Anybody got a lead on who has them for relatively few AMUs for common sizes
like 600-6 and so on?
Michelin sells them as AirStop tubes. Chief Aircraft carries them.
Rip
Old May 13th 07, 02:33 AM posted to rec.aviation.owning
Kyle Boatright
Default Inner Tubes
"Rip" wrote in message
severely as the old
Flyer.
sizes like 600-6 and so on?
Rip
And they are not cheap. I believe Goodyear has come out with a version too.
Desser carries both brands.
IIRC, my 5" x 5" airstop tubes were $30+ each. New tires were $50/ea. It
hurt paying almost as much for the tubes as the tires. Still, only having
to air the tires 3 or 4 times a year is nice.
KB
KB
Old May 13th 07, 05:03 PM posted to rec.aviation.owning
Mike Murdock
Default Inner Tubes
Where else but in aviation do you have to pay extra to get inner tubes that
don't leak? You gotta love it.
-Mike
too.
KB
Old May 13th 07, 05:51 PM posted to rec.aviation.owning
John Clear
Default Inner Tubes
Bicycling has the same issue. I lose ~40psi a week out of the
tires on my bike. Of course, I'm starting at a much higher pressure.
The tires on my road bike have a recommended pressure of 100psi.
I have upgraded tubes for when I need to replace the existing ones,
but it is easy enough to add air that it isn't worth trashing good
but leaky tubes.
John
John Clear - http://www.clear-prop.org/
Old May 14th 07, 04:34 PM posted to rec.aviation.owning
Dave Butler
Default Inner Tubes
My understanding is that there is an actual technical issue. The kind of
rubber (butyl?) tubes that don't leak are difficult to make in small
tire sizes with small radius of curvature.
Dave
-Mike
too.
KB
Old May 16th 07, 01:01 AM posted to rec.aviation.owning
Roy N5804F
Default Inner Tubes
Dave,
Your on the right track Dave.
I hold patents on inner tube joining machinery and as you say there is a
difficulty in using a regular joining machine at the smaller sizes.
Butyl inner tubes have been around since 1970.
An inner tube is made from a straight length of "tube" and then joined end
to end in a "joining machine"
Semperit Tyres produced and licensed the first joining machines that were
successful on butyl.
Goodyear Tire [licensed by Semperit] was supplying "airstop" tubes through
the 1970's.
Butyl is a oil product and significantly lower in cost than natural rubber.
However, natural rubber "joins" much more easily than butyl and therefore
remained the tube to use for the aviation industry.
And of course being for aviation, butyl tires are now sold at a premium, but
are most definitely lower cost to make because of lower raw material cost.
Roy
Piper Archer - N5804F
"Dave Butler" wrote in message
that don't leak? You gotta love it.
rubber (butyl?) tubes that don't leak are difficult to make in small tire
Dave
-Mike
too.
It hurt paying almost as much for the tubes as the tires. Still, only
having to air the tires 3 or 4 times a year is nice.
KB
Where can you get empty caulking gun tubes... Jerry Wass Home Built 16 March 3rd 11 05:36 PM
Connecting hoses to pitot/static tubes Ernest Christley Home Built 9 October 23rd 06 02:44 PM
Wanted: NON FUNCTIONAL VT-4-C and VT-25 vacuum tubes, other gear for B-17 setup Juan Jimenez Aviation Marketplace 7 September 19th 06 11:20 PM
Leak proof tubes Roger Owning 9 December 8th 05 10:15 AM
Seeking US Source for Main Wheel Tubes Chris OCallaghan Soaring 7 August 28th 04 04:46 PM
