#21
Thomas Borchert wrote:
To expand: My experience with these simpler devices is that if you have more than, say, two close-by targets (a typical situation in a busy pattern), they become useless since you'll be busy looking outside. I turn our voice alerting off on the Monroy in these cases, since it will just say "traffic nearby" all the time and show a distance of a mile. I know that already, so I look outside. I'm not familiar with the Monroy, but it's threat determination doesn't sound as good as the MRX. To quote from a post I made: "I'm also using an MRX. I believe it's warnings are also based distance and altitude trends, not just distance and altitude. For example, consider two aircraft the same distance from you and the same altitude above, one descending and one ascending. Only the descending one will trigger the alert signal." In other words, the MRX "advisory" and "alert" warnings are not based just on traffic being nearby, but actually approaching your position. In addition, it displays distance down to 0.4 mile. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Eric wrote: I'm also using an MRX. I believe it's warnings are also based distance and altitude trends, not just distance and altitude. For example, consider two aircraft the same distance from you and the same altitude above, one descending and one ascending. Only the descending one will trigger the alert signal. This "trend" clarification is a very important distinction. Thank you for pointing it out. It helps to explain why sometimes aircraft are within the MRX parameters, but don't trigger the beep-beeps. |
| Thread Tools | |
| Display Modes | |
| PCAS - Portable Collision Avoidance System | [email protected] | Soaring | 13 | October 14th 06 08:21 PM |
| Collision Avoidance and ATC | Bubba | Soaring | 5 | September 1st 06 05:31 AM |
| Collision Avoidance Systems | [email protected] | Products | 0 | May 21st 06 11:15 PM |
| Collision avoidance equipment | samcapt | Products | 2 | May 13th 05 05:41 PM |
| Collision avoidance device | Jim Hendrix | Soaring | 1 | October 19th 04 10:24 AM |
