You wrote
On Oct 2, 9:57 pm, Le Chaud Lapin wrote: Hi, Student pilot here, self-teaching using the Jeppensen Private Pilot Kit after taking ground school. ![]() I read in the book that combustion "creates" energy, which is technically not true, but I decided to ignore it since the pictures are sooo pretty. Now, in Chapter 3, section about airfoils, it actually says: "In addition to the lowered pressure, a downward-backward flow of air also is generated from the top surface of the wing. The reaction to this downwash results in an upward force on the wing which demnstrates Newtons' third law of motion. This action/reaction principle also is apparent as the airstream strikes the lwoer surface of the wing when inclinded at a small angle (the angle of attack) to its direction of motion. The air is forced downward and therefore causes an upward reaction resulting in positive lift." IMHO, the latter part of this paragraph is correct, but the former part is wrong. Obviously, any air above the wing can only result in a force downward on top of the wing. The only force causing the plane to want to move upward comes from beneath the wing. The effect of any air above the wing is to cause rarefication above the wing, resulting in lower pressure, thereby giving the 14.7lbs/in^2 (plus) to do its work. That "reaction" coming from downward movement of air seems just plain silly to me. You would do well to think in terms of differential pressure. If one can by some means cause the pressure on the upper surface of the wing to be 1 psi less than the pressure on the lower surface, there would be an upward force on the wing of the order of 144 pounds per square foot (my physics training, a million years ago, was in english units). You might also want to think carefully about airfoil shapes, since wings can provide lift when flying inverted. Any theory that does not support inverted flight is obviously flawed. But the neat thing to do is to hold your hand out of a moving car's window, and feel the impact pressure on its surfaces as you tilt it in the airstream. It's not that the hand is being "sucked" up, you don't feel suction on the top surface, you feel push on the bottom one. Any theory you develop had better be consistant with those observations. Someone with more time than I have might like to start with the fact that air weighs about .08 pounds per square foot near sea level, and crack some numbers to show how that deflecting that mass can result in lift even if the lifting surface has some funny shapes. |
| Thread Tools | |
| Display Modes | |
| How much lift do you need? | Dan Luke | Piloting | 3 | April 16th 07 03:46 PM |
| Theories of lift | Avril Poisson | General Aviation | 3 | April 28th 06 08:20 AM |
| what the heck is lift? | buttman | Piloting | 72 | September 17th 05 12:50 AM |
| Lift Query | Avril Poisson | General Aviation | 8 | April 21st 05 08:50 PM |
| thermal lift | ekantian | Soaring | 0 | October 5th 04 03:55 PM |
