In my experience, a stall break while straight and level or in a 60 degree
bank if perfectly coordinated will drop the nose straight down. The kicker is that 98% of the pilots have lazy feet and don't really keep the aircraft coordinated. If power is ON, the aircraft will need more rudder to control yaw and that amount of rudder will increase as speed is decreased approaching the stall. Some airplanes may not have enough rudder to stay coordinated to the stall, most pilots will not use the rudder that is available. Some airplanes will not spin, even wit yaw supplied by maximum rudder input at the stall in a pro-spin direction. The Beech Skipper [BE77] requires that the stall be entered, just before the stall, full pro-spin rudder is applied to induce a roll. At a 90 degree bank angle, sudden and full aileron in the opposite direction as the rudder is necessary to stall the wing crisply at the outer half. That will cause the airplane to roll rapidly and enter a spin. If not timed or done correctly, the aircraft will enter a spiral. In the accidental spin, the pilot is likely to do exactly the same thing, just not with thought and skill. The plane is stalled while yawing [uncoordinated] and when the break happens, the poorly trained and non-current pilot's reaction will often be to try to pick-up the wing that is falling and the nose with aileron and up elevator. The natural reaction, which training and experience correct, is to "fight" the falling nose, the falling wing, with normal control input. IF the aircraft is coordinated perfectly, the difference in lift vector is due slightly to the radial airspeed difference between the L&R wings, but more my the dihedral built in the airplane. The problem is that flight is very dynamic, control forces are changing, humans have reaction times, and the control authority created by the aerodynamic surfaces rapidly falls with a small decrease in airspeed [lift equation] and the other forces, such as P-factor and engine torque involve inertia and mass. "Todd W. Deckard" wrote in message ... | | "Dudley Henriques" wrote in message | ... | There is only one thing you have to know about spins. To enter one you | need 2 things to be present; stall and a yaw rate. | | So to corner your answer to my question: you cannot? spin from coordinated | flight. | The airplane must be yawed during the stall break (thus the inclinometer | ball slips or skids | to one side). | | My question is not to seek out practical advice in spins, or recoveries. It | is to explore two | academic debates: Can a certificated airplane depart if the ball is | precisely in the middle | and is there something telling in the emphasis from the foreign sources | cited that exposes a | gap in our US training practices and material. | | Thank you for your response. | | I'll be making a new years resolution to try it out in the neighboorhood | Decathalon (with an appropriate | chaperone) but as it is cold and snowy I thought I would put it to the | uunet. | | Best regards, | Todd | | |
| Thread Tools | |
| Display Modes | |
| Coordinated turns without rudder, and autopilots | Mxsmanic | Piloting | 188 | June 1st 07 08:09 PM |
| Coordinated turns and the little ball | Mxsmanic | Piloting | 51 | October 11th 06 11:17 PM |
| Is rudder required for coordinated turns? | Mxsmanic | Piloting | 41 | September 24th 06 07:40 PM |
| Snap / Flick and spins in flight simulators | [email protected] | Simulators | 1 | September 2nd 06 08:10 AM |
| Coordinated turning stall and spins | Chris OCallaghan | Soaring | 20 | November 18th 03 09:46 PM |
