Andy Asberry wrote:
3/4 ton extended cab pickup towing a 24 foot travel trailer. Fuel mileage is effected much more by wind than weight. I want to build a camper shell that will be cab high at the front and direct the airflow smoothly over the trailer. There is about 4 feet between the front of the trailer and the rear of the proposed camper. For some reason, I believe the camper should be higher than the trailer. But how much higher? Should the angle be constant? Convex? Concave? A different exit angle? About a foot from the top of the trailer, the front slopes back at a 45 degree angle. All opinions are welcome but educated calculations will be given more weight. ![]() --Andy Asberry-- ------Texas----- I'd be betting against making the camper higher than the trailer. At least on a/c, drag is reduced if the trailing body is slightly larger than the object ahead of it. Ailerons with leading edges that are slightly fatter than the wing trailing edge come to mind. If you can't make a smoothly faired transition to a smaller cross section, the drag will go up a lot. Think round gear leg vs one with a teardrop shaped fairing. Take a look at big tractor-trailer rigs. the air dams on the tractors aren't higher than the trailers. Charlie I'm not an aerodynamicist, but I do know one. :-) |
| Thread Tools | |
| Display Modes | |
| Aerodynamic question for you engineers | Pete Brown | Piloting | 73 | January 28th 08 05:06 PM |
| Commercial rating: complex aircraft required aircraft for practical test? | Marc J. Zeitlin | Piloting | 22 | November 24th 05 05:11 AM |
| Aerodynamic Drag | Kyle Boatright | Home Built | 7 | September 26th 05 04:34 AM |
| Aerodynamic Simulation of Standard Cirrus Glider | Jim Hendrix | Soaring | 13 | November 10th 04 12:38 AM |
| Airfoil aerodynamic simulator... | Thomas J. Paladino Jr. | Piloting | 4 | May 17th 04 03:41 PM |
